Author Topic: Sprocket bolts snapping off - Removing Bearing Retainer???  (Read 7383 times)
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
Re: Sprocket bolts snapping off...
« Reply #25 on: July 18, 2010, 01:57:51 PM »
the NUTS, not bolts in a stock 500 hub should have bendable long washers underneath, they are there exactly to prevent this very dangerous situation. could end in tears. if you omitted them while fitting your rear sprocket slap your own hands, if its the PO, then find him and kill him... ;)
TG
Example of what sprocket lock washers might look like.
Anyone got a spare sprocket lock washer.  Mine is shot now.  >:(
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline IndyFour
Re: Sprocket bolts snapping off - w/ pix b4 I fix
« Reply #26 on: July 18, 2010, 01:59:58 PM »
Looking at Frostyboy's exploded diagram above....could it be that the threaded studs (part #19) that go into the cush drive are longer on one end than the other....and that they were put in backwards, causing them to stick out past the nuts?  I've had my back axle apart to replace bearings, but I never removed these studs to know if they are the same length (thread-wise) on both ends.  Just a thought.
« Last Edit: July 18, 2010, 02:01:32 PM by IndyFour »
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #27 on: July 18, 2010, 04:28:26 PM »
Is it possible that the stud has been vibrating/turning...and working its way out...while the nuts because it is locked stays where it is??
I wouldn't think so, at least not for all 4 to loosen off simultaneously.
Curious question but shouldnt the axle nut be on the other side (right hand side)? I have no experience with 550s but on all the 750s I have seen its been on the right.
Andy
The axle nut is on the left (chain side) on the 500/550.  I never realized that it was different for the 750 until you asked that.   :)
Mine was originally on the L/H/S, but I changed it to the R/H/S so I didn't have to remove the muffler when I wanted to remove the rear wheel. It doesn't appear to have made any difference.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline turboguzzi
« Reply #28 on: July 19, 2010, 04:30:05 AM »
studs should definitely be almost flush with the nut's top surf. if not, they've been put the other way around.
TG
Offline Frostyboy
  • Circa 1951
« Reply #29 on: July 19, 2010, 05:14:04 AM »
I'm puzzled here again. I've cropped your pic #1 and then took a pic of my drive flange with the spacer in place.
Is it just me, or does it look like the spacer is missing in your pic or are the tin plates a different shape?
It seems that the whole setup on your machine is a lot closer to the chain adjuster than mine would be if it was mounted.
Maybe someone else can take a pic at the same angle as your #1 & post it.
We haven't met yet.
[CB550F1]
Offline brycegp
« Reply #30 on: August 01, 2010, 08:57:27 AM »
UPDATE:
I am finally fixing this thing.  After it took FOREVER to get my new Cush Drive and new bearings...and a couple other odds and ends.
This is where I am.  I removed the rear tire...but on the Cb500 there is a retainer ring (screws into the hub) that holds in the bearings.  But more importantly, it holds on the Cush Drive.   I don't have a tool to get it off.  And the installer put it on there GOOD AND TIGHT.
Any suggestions on where to get a tool to remove it??
WIDE of TIRE:
Close up of retainer rings:
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Sprocket bolts snapping off - Removing Bearing Retainer???
« Reply #31 on: August 01, 2010, 09:10:55 AM »
You could either buy the custom Honda tool or fab one yourself with bar stock and welding tabs to go in the recesses- people in here have done it before.
Bearing retainer removal page
« Last Edit: August 01, 2010, 09:24:13 AM by Dukiedook »
Offline SohRon
« Reply #32 on: August 02, 2010, 03:03:38 AM »
Actually, it looks like your spacer might be in backwards, Frosty... the "collar" or "shoulder" fits down on the bearing while the rest of it extends out through the plate. His looks like it's in right, but definitely looks too short. Here are some pics to demonstrate:
« Last Edit: August 02, 2010, 03:15:13 AM by SohRon »
Offline IndyFour
« Reply #33 on: August 02, 2010, 05:46:37 AM »
UPDATE:
Here's another thread showing how to get it off.
http://forums.sohc4.net/index.php?topic=58147.0
Make sure you drill out the stakes first or you will never get it off....even with a special tool.  I used a large flat blade screwdriver and tapped the retainer via the holes to turn the retainer clockwise (it is reverse threaded on the 500/550....in this case righty is NOT tighty...it's loosey).  This was after the stakes were drilled out.  Mine came off fairly easily, but I have heard of people having to use heat to get it loose.
« Last Edit: August 02, 2010, 05:51:12 AM by IndyFour »
1974 CB550K
2000 VFR800FIY
__________________
Offline Frostyboy
  • Circa 1951
« Reply #34 on: August 02, 2010, 06:46:03 AM »
Doh, thanks for pointing that out SohRon, you're right. It's been that way since I can remember. I must put that right before the wheel goes back on.
Cheers.
We haven't met yet.
[CB550F1]
