Author Topic: tank badge metal  (Read 1273 times)
Offline octagon
tank badge metal
« on: July 13, 2010, 07:34:53 PM »
is it safe to bend a tank badge? one of mine doesn't have quite enough curve so it doesn't conform to the tank properly. the metal looks like it might break if you tried to bend it.
Offline Accolay
Re: tank badge metal
« Reply #1 on: July 14, 2010, 08:43:06 AM »
It's ok to bend. Just be gentle.
1977 CB550F
« Reply #2 on: July 14, 2010, 09:41:12 AM »
Would heat help? hairdryer?
Offline markb
  • When I finish my current project I might be a
« Reply #3 on: July 14, 2010, 10:42:26 AM »
I believe Yamiya recommends warming their replacement tank badges.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline octagon
« Reply #4 on: July 14, 2010, 12:18:48 PM »
will try this evening, maybe using a heat gun, and report.
bobjohnson
« Reply #5 on: July 14, 2010, 12:55:16 PM »
I used a heatgun on my 450 badges (not a sohc, i know :P). Theyre actually pretty bendable as is, i think theyre aluminum.
Offline Steve F
« Reply #6 on: July 14, 2010, 06:32:46 PM »
I believe they're diecast zinc, and that takes about 500 degrees F to get them to soften up.  I was able to VEEEEEEERY  GENTLY bend mine cold without cracking them.  Just take your time and be careful not to bend too far cause they don't like being bent back!
Offline octagon
« Reply #7 on: July 14, 2010, 06:53:27 PM »
i didn't want to heat the metal to 500 degrees, so i bent it cold - this is a tank badge on a 76 cb750k - it did bend ok.
i found it took a good bit of force to start the metal moving. but i had to back off rapidly on the bending force once the metal started to give - it was a little surprising. not like bending iron. it would be easy to overdo it with this kind of metal, whatever it is, and bend too much.
Offline Accolay
« Reply #8 on: July 14, 2010, 09:27:58 PM »
Nah, just use Uri Geller.
1977 CB550F
