Author Topic: Chainguard Thread  (Read 5979 times)
Jeremy
Chainguard Thread
« on: March 29, 2005, 05:10:55 PM »
I went to try and get my 77 550k  MOT certified today and they would not pass me without a chainguard. Here's my problem, have a 750f2 swingarm, comstars and rear disk setup. The little 550 rear sprocket and the 750 chainguard look stupid and the 550 chainguard doesn't fit the swingarm. Any suggestions?
DickB CB500F
Re: Chainguard?
« Reply #1 on: March 30, 2005, 11:40:29 AM »
The one I have, although it sounds gash, looks quite effective.  It may even be an aftermarket item (I'm going from memory here, as I'm going back over 10 years since it was lost to the dark depths of my garage!).  It is essentially a couple of bits of lightwieght angle iron, welded together to pass over the chain and rear sprocket, plus brackets.  My bike never had problems passing its MOT with it on and it should be easy enough to fabricate.
carsholduptraffic
Re: Chainguard?
« Reply #2 on: March 31, 2005, 02:45:20 AM »
mine is a length of 6mm alloy flat bar with two alloy angles to attach it to the swingarm made up from 3mm sheet. stuff you can get at a big hardware shop. i used epoxy(permatex cold weld) and pop rivets to attach every thing, and it hasn't moved in 60'000kms. legal and light. all you need is a drill, m6 bolts to attach it, and a big hammer. and a vice is good if you whack thigs with a big hammer. but aluminium is fun. get the brackety right and get creative!
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
750 K0 Chainguard.
« Reply #3 on: June 28, 2005, 07:41:23 AM »
Was the cahinguard for the K0 plastic?
I was looking at what claims to be the first CB750 imported into the UK and it had a plastic one fitted.
Was this standard or has it been replaced over the years. The owner wasn't about so I had no one to ask.
Also I dissapointed to note that it wasn't a sandcast, so can only presume none of the realy early bikes were officially imported. Probably explains why they go for so much over here.
In the UK anything over 40 years old only needs insurance and Fuel.
Offline dusterdude
Re: 750 K0 Chainguard.
« Reply #4 on: June 28, 2005, 07:49:35 AM »
my k1 is plastic
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: June 28, 2005, 08:33:52 AM »
My K0 chaingaurd is plastic. It should have the short rear end on it also, in other words does not extend out to the rear but more or less follows the rear sprocket conture. Later guards were extended to try and keep chain lube off the rear rim.
Offline dusterdude
« Reply #6 on: June 28, 2005, 09:26:39 AM »
bob,mine is the contoured style
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: June 28, 2005, 11:47:44 AM »
I'm not sure when the gaurd changed to the longer version, but I believe it may have started with the K2. The K2 part has a different and 341 model code in the part.
Offline Raul CB750K1
« Reply #8 on: June 29, 2005, 01:12:42 AM »
K0 and K1 had the plastic chainguard. From K2 on it was replaced by the metal chainguard.
First versions (sandcasts and some K0's) had the short type. After complains of grease being thrown to the rim the chainguard was elongated, as well as some other changes like new ribbed front mudguard and fork legs.
Raul
Offline Kevin D
  • SE Michigan
« Reply #9 on: June 29, 2005, 03:57:16 AM »
KO has short plastic guard, K1 has long plastic guard.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Online bryanj
« Reply #10 on: June 29, 2005, 08:27:45 AM »
Sandcasts were never OFFICIALY imported into UK, although quite a few are here now. So its quite possible to be an early UK model. There may have been a K0 press model but not even Honda can confirm or deny that one.
kaysystems
« Reply #11 on: June 29, 2005, 09:34:12 AM »
The original K0 changuard is 24 inches long & plastic. There was a Honda recall to replace them with a longer one. Lucky me...I have the short one.
David ;D
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: June 29, 2005, 10:00:11 AM »
Never realized they were a recall issue, guess my PO ignored it.. like so many other things.  ;)
kaysystems
« Reply #13 on: June 29, 2005, 02:34:34 PM »
I only say it was a recall, because it is mentioned as a must do in the Service Bulletins.
David
Offline Mark M
« Reply #14 on: June 30, 2005, 12:26:36 AM »
There was a pre-production bike that did a tour of the European bike shows, quite a few changes made prior to production, but I assume that went back to Japan in 69.
kaysystems
Early chainguard info
« Reply #15 on: September 18, 2005, 04:15:13 PM »
Can anyone send me a photo of an early - Sandcast or K0 - short rear chainguard. I have a long one, anddon't know what the short one looks like, so that I can start searching. A photo on a bike would be fine.
thanks
David
kaysystems
Re: Early chainguard info
« Reply #16 on: September 18, 2005, 04:21:32 PM »
Does this look correct? I have a 'short' that I was sold that ain't like this. Mine has a completely straight front & not so curved at the back.
David
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #17 on: September 18, 2005, 04:36:45 PM »
Here is what a I believe is a short chaingaurd. The later gaurds, rather than conforming to sprocket, extended further back to prevent oil, etc. from getting on the rear rim, or that was the theory anyway.
kaysystems
« Reply #18 on: September 18, 2005, 04:45:57 PM »
Thanks Bob. That looks like the one I aquired, not like the one in my photo.
Read somewhare that the original short is 24" long
Maybe the one in the photo is from a 500?
Thanks
David
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #19 on: September 18, 2005, 05:34:38 PM »
Bob,
Not only to keep oil  off the wheel...but also the back of your shirt! >:(
Been there...know that.  I added a short extension to my chainguard.
Unfortunately, that created two small holes in the guard. ::)
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #20 on: September 18, 2005, 05:50:35 PM »
I know what you mean. I usually had a small duffel with camera, etc. on a luggage rack on most rides. It, and the underside of the luggage rack made great collection points for recycling chain lube.
chainguard
« Reply #21 on: January 20, 2006, 04:19:45 PM »
Can anyone tell me if the chrome 550 supersport chainguard will replace the K model guard directly?
Thanks
Offline 78 k550
Re: chainguard
« Reply #22 on: January 20, 2006, 06:27:52 PM »
I think there the same. I was checking out a 550F chrome one in the yard. Looks like new. Looks like it bolts up the same.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Re: chainguard
« Reply #23 on: January 20, 2006, 07:34:54 PM »
Thanks Paul,
You don't have a spare for sale by any chance?
Offline 78 k550
Re: chainguard
« Reply #24 on: January 21, 2006, 07:45:51 AM »
I can swing buy the yard and get a price for you. Are you looking for a 550F chrome chain guard or a K?
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
