Author Topic: Fuel valve re-assembly  (Read 671 times)
Offline jbonham
  • Um, do you know where this goes.......?
« on: July 16, 2010, 09:13:06 AM »
I have cleaned the fuel valve assembly for my K1 and now I am putting it back together and am not sure where the spring goes. Does the spring go between the outside plate and the valve handle or between the valve handle and the gasket on the inside? I have looked at the fiche from Service Honda but I get lots of resistance when assembling based on the fiche diagram.
Let me know if you need more info.
1971 CB750 K1
2003 Kawasaki Vulcan Classic 1600
Offline jbonham
Re: Fuel valve re-assembly
« Reply #1 on: July 16, 2010, 09:20:51 AM »
Nevermind. I did some more searching here for petcock assembly and found what I was looking for.
Thanks
1971 CB750 K1
