Author Topic: How to remove throttle from CB500? (Installing Clubmans)  (Read 2649 times)
Offline KCRSXTypeS
  • 1973 CB500
« on: July 14, 2010, 09:40:59 AM »
Hey guys, I am in the process of installing clubmans and the only part I have left to do is remove the throttle from the right side of the handle bar.  Im having trouble getting it off so I can remove the whole handlebars...what am I doing wrong?
Offline Gordon
  • 750K1, 550K2
Re: How to remove throttle from CB500? (Installing Clubmans)
« Reply #1 on: July 14, 2010, 09:45:55 AM »
You still have the stock bars on with the wires running through them?
Offline KCRSXTypeS
  • 1973 CB500
« Reply #2 on: July 14, 2010, 09:46:12 AM »
yes and no...they are kinda just hanging there.  All the wires are still in the headlight housing, the clutch cable and brake line are disconnected but the other wires and throttle cables are still attached.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: July 14, 2010, 09:47:24 AM »
I don't understand.  Are the wires for the switches and starter button running through the bars or not?
Offline KCRSXTypeS
  • 1973 CB500
« Reply #4 on: July 14, 2010, 09:49:07 AM »
Yes, the wires for the switches are running through the stock bars and the stock bars are still on...people talk about how to install clubmans but never give instructions for removing stock bars lol.
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: July 14, 2010, 09:53:38 AM »
You need to disconnect the throttle cables at the carbs, and then disconnect them from the inside of the throttle grip.  Once you've done that and you have unplugged all of the corresponding wires inside the headlight bucket you should be able to pull the throttle grip off and pull the wires out along with it.
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: July 14, 2010, 09:54:41 AM »
It helps a lot if you feed the wires in from the back as you're pulling.
Offline KCRSXTypeS
  • 1973 CB500
« Reply #7 on: July 14, 2010, 09:54:51 AM »
grrrrrr...was hoping to not have to remove the cables at the carbs...I guess its the easiest way though...its just a pain in the ass to get the cables back into the carbs later.
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: July 14, 2010, 09:56:10 AM »
If you're installing clubmans you're going to have to either re-route the throttle cables or replace them with shorter ones anyway.  Same with the brake and clutch lines.
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: July 14, 2010, 09:58:54 AM »
Oh, and you'll have to cut out a notch in the bottom half of each switch pod to run the wires externally, too.  And either drill holes in the bars for the switch pod locating pins or just pull the pins out.
Switching to non-stock handlebars for the first time is never as simple as you think it will be.  It can easily turn into a full day or even a weekend project if you're not experienced at it.
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: July 14, 2010, 10:28:44 AM »
Am I being a wet blanket again? ::)
Offline KCRSXTypeS
  • 1973 CB500
« Reply #11 on: July 14, 2010, 11:00:08 PM »
Didn't have to notch the handle bars...ran them out the end right before the bend, and the stock throttle cables and brake lines I made work just fine.  Rides great!  Took me about 6 hours which would have only been about 4 had I had a good drill and didn't have to wait for mine to recharge...
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: July 14, 2010, 11:06:16 PM »
Sweet!  You were much faster than I was the first time. :)
Offline KCRSXTypeS
  • 1973 CB500
« Reply #13 on: July 16, 2010, 09:09:16 AM »
That's what she said... ;D
