Re: '77 CB550F - sorry this is so long but please, I need your experienced help.
This problem may/may not be related to my recent "No headlight & no left-front turn signal problem which, thanks to you guys, was corrected by running a new ground wire. [I was "borrowing" Seannh's current post about his headlight/turn sig problem.]
The bike has quit 5 times - just like turning the switch off. Four times, I turned the ign switch off, pulled over and moved the petcock to Reserve. Each time, the bike started right up. Once I got the petcock to Reserve before I got stopped and the engine picked back up and went on. Every time it did this, I switched the petcock back to Running position and it would quit again - sooner or later. So, like a dummy, I replaced the petcock [with an NOS petcock] - which appeared to be the cause of the problem.
When I replaced the petcock, I drained the tank all but about 1/2 gallon through 2 new paint strainers. I sloshed this good, poured it out the filler opening onto a clean white cloth. Absolutely no trash in the paint strainers or on the cloth! Tank filter looks new. Inside of tank bright and shiny. Nothing in a transparent extra fuel filter in the fuel line. Carbs done late last summer.
New petcock didn't prevent engine stopping. Next time out it quit as before. I changed to Reserve and completed a 100 + mile trip with no other problem.
Next time out I got about 60 miles and , running on Reserve, it quit again [6th time]. THIS time the idiot lights didn't come back on with the ign switch.
It had blown the Main Fuse! [Never was a fuel problem!] I put another 15 A fuse in and got about 2 miles and it blew again [7th time]. Getting dark - I put a 30 amp fuse in it and rode it home. Strangly, coming in, I had no tail light - ALL other lights normal. An hour later, I turned the switch on and the tail light came on [didn't start engine].
Next day I rode it 7 miles to a good mechanic. All lights normal. He checked wiring for over 2 hours and found nothing wrong. Put the 15 amp fuse back in and rode home [all lights normal].
The next day I found the no headlight/left fr turn sig outage - which was corrected by a new ground wire today. [This likely caused the tail light problem,too.]
Is there any way the bad ground could cause the blown main fuse or is this another problem? Could it be in the ign switch?
I appreciate your time and your experienced help.
Thanks
