Author Topic: Squealing brakes have me howling mad!  (Read 11245 times)
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Squealing brakes have me howling mad!
« Reply #25 on: July 12, 2011, 07:28:20 AM »
Original Honda pads might help, the EBC material is known for it's Ned Beatty ala Deliverance ability to squeal like a pig.
Offline socalenduro
« Reply #26 on: July 12, 2011, 11:34:22 AM »
you got a perdy mouth boy
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #27 on: July 12, 2011, 11:58:18 AM »
I read a post from HondaMan mentioning that EBC will provide a 3M shim for free that is supposed to reduce the vibration, and hence the squeal.  I emailed them, and almost immediately received a response asking for my mailing address.  That was 3 weeks ago, and after 2 unanswered emails sent, I finally just called them.
  Whoever I spoke to on the phone took my info and promised to send them out. I will report back, because I just swapped to braided lines, new Kevin piston and all new fluid, and it is the worst squeal I've ever heard.  Beyond embarrassing, it hurts my ears even with full-face helmet on!!!!
I'll try all these other moves too - because this Noise has to go!
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #28 on: July 12, 2011, 12:22:41 PM »
All my squeaking problems stopped after the drilled disc went on.
Offline wingman1946
    • BCINKART.com
« Reply #29 on: July 12, 2011, 12:50:21 PM »
This may sound to easy but my squeal was removed with thorough cleaning of the rotor with brake cleaner and a couple passes of the pads on a sheet of 220 sandpaper.
Offline socalenduro
« Reply #30 on: July 12, 2011, 03:30:34 PM »
did you take the wheel or caliper off to perform the cleaning?
Offline wingman1946
    • BCINKART.com
« Reply #31 on: July 12, 2011, 04:50:21 PM »
The caliper was off and tied away from the rotor and covered. I made sure the wheel was completely covered to keep the cleaner off of it as well. Don't get the cleaner on anything but the rotor !!
Offline pablo78cb550
  • mmmph.
« Reply #32 on: July 12, 2011, 05:06:03 PM »
i from the get go of my resto, i installed a composite caliper piston, never heard a peep from my front brake.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline socalenduro
« Reply #33 on: July 13, 2011, 07:31:23 AM »
What I'm suggesting is that in all these repairs that got the brake to stop squealing the rotor/pad/caliper were realigned when put back together. This is why these repairs sometimes work and sometimes do not.
Squeal is from the contact angle of the pad and rotor and the vibration it creates.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #34 on: July 13, 2011, 07:49:55 AM »
I've got the same issue and have tried just about everything EXCEPT there's a thread on here somewhere where someone noticed that the pivot pin for the caliper arm had worn and would allow enough motion that they shimmed it (somehow).
Is the pivot pin #13 in this diagram?
Thanks
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #35 on: July 13, 2011, 07:55:17 AM »
I use my brakes to predict the weather. If they squeal loudly it's going to rain. If they don't squeal much, it's going to be a nice day. Not sure I want to get rid of that!  ;D
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #36 on: July 13, 2011, 07:56:46 AM »
I wouldn't doubt if that is more accurate than ANY of the weathermen around here.... :)
I would love to get rid of this squeal, because it has become nerve wracking and headache inducing!
~Sophocles
Offline Spanner 1
« Reply #37 on: July 13, 2011, 08:05:28 AM »
Pin =13 arm = 12... watch out for the 2 seals ( 41 ) if you take it apart. With the caliper undone the arm must be free and move left and right  ( take the adjusting screw, nut, spring off too ).
« Reply #38 on: July 13, 2011, 08:38:34 AM »
is that why you didnt ride to work yesterday?  ;D
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #39 on: July 13, 2011, 09:10:34 AM »
Thanks!  I'll watch for the 2 seals.
~Sophocles
Offline Really?
« Reply #40 on: July 13, 2011, 09:41:07 AM »
Something I seem to remember, it has been a while, is that you are supposed to check and adjust the floating distance with a feeler guage.  I mention this because I do not see anyone ever mentioning it.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #41 on: July 13, 2011, 09:49:52 AM »
I did use the feeler - but have to admit it was a pain to get in there correctly, and I ended up going by "feel" in the end with the spinning of the wheel - settling on when it JUST stopped spinning from friction.
~Sophocles
Offline johnny
« Reply #42 on: July 13, 2011, 10:41:15 AM »
I've recently experienced an ear-piercing squeal from the front brake also, which I foolishly assumed was just what these old Hondas did - with no definitive remedy.
After reading this thread, I figured I'd take a shot at correcting the problem.
I wiped both sides of the front rotor with a rag containing a few sprays of brake parts cleaner (note: I did not spray directly on the rotor) - being careful to rotate the wheel to access all areas while not touching other parts. Then, I lightly sanded both sides with very fine (220 grit) sandpaper to remove the dark "glaze" present on the rotor. Lastly, I followed up with another wipe of the rag and brake parts cleaner, making sure the rotor was clean and dry.
No more squeal! I'm not sure how long this fix will last but it was squeak-free on my entire commute to work.
I'm sure there's a logical scientific explanation to this but I like to think of it as magic!
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline Godffery
  • Godffery's Garage
« Reply #43 on: July 13, 2011, 12:59:36 PM »
I've tangled with that issue a number of times and it seemed like a verity of slotions worked (seemed like something different each time) but only for a while, then reoccurred.
In the past 6 months I've developed the most effective long term solution to date:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/album185/Anti+squeal+Brake+Insulators/
BTW; I also recommend removing the adjustment Screw, nut & spring; then put them in a safe place where they'll never be seen from again!!!
« Last Edit: July 13, 2011, 01:12:55 PM by Godffery »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #44 on: July 13, 2011, 01:41:33 PM »
Yes out of sheer embarassment from squeaky brakes.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #45 on: July 13, 2011, 03:26:39 PM »
I am pretty sure this is what EBC is sending me - if they ever get their #$%* together.
Also, what are you talking about with the adjustment mechanism????
~Sophocles
Offline Tintop
« Reply #46 on: July 13, 2011, 03:50:43 PM »
Removing items # 14 /15/49 /46 in the above parts diagram.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline brooze72
« Reply #47 on: July 13, 2011, 04:01:24 PM »
[/quote]
So based on the diagram this would let the caliper float freely & take care of squeal?  Or is that only if you have squeal before application of the brakes?
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #48 on: July 13, 2011, 04:27:25 PM »
Sorry, I understood which parts, just trying to determine if he was being facetious.
~Sophocles
Offline Redrider969
  • "What fun to be on the road again." B. Baggins
« Reply #49 on: July 13, 2011, 04:44:04 PM »
The variety of solutions proposed to eliminate your problem has made for very interesting reading.  Please keep us posted on which solution(s) you try and the results.
Redrider969
