?Questions? I picked up a later 550 rocker cover with the locked shafts, but one of the rockers is scored, can I replace a rocker individually? And, does it need to be from a later model cover?
I got a nice 550 cam shaft for the spare 500 motor, not sure if there's a performance boost from 500 to 550 cams? That motor turns freely, but has sat for a few years. The compression is low in #1 (~75) but I think it may come back up with a little sea foam soak and some running.
The 550 motor soaked with atf/acetone for over a week, but the 2 and 3 cylinders STILL won't budge
![Angry >:(](http://forums.sohc4.net/Smileys/default/angry.gif)
I may have to take it to my pop's shop and get some help. I can't imagine I wouldn't need a re bore, and I'd really like to find a good big bore kit for this engine, but either way I'll be ordering some kibblewhite valves when they come out in next month.
