Ok, my CR carbs have arrived, and I have a question that I hope some of you may be able to help with. Each carb has a 90 degree elbow fitting coming off of it, and the fuel tube going between the carbs has a T-fitting that is there as well.
Now....I'm guessing the T- fitting going between the carbs is the fuel inlet from the tank....and the individual fittings are overflows?
Please help!
~Joe
