Author Topic: rocker tower placement  (Read 985 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: July 23, 2010, 05:56:05 AM »
I just got a 71 CB750 K1 basket case and the head has been removed and the cam and part in a bag. How can I figure out which towers go where since these are matched parts and need to go back together the same way they came apart - right?
Re: rocker tower placement
« Reply #1 on: July 23, 2010, 05:59:44 AM »
Left to right, no way of knowing, don't matter, flip a coin. The bearing caps are alpha/numeric coded to the holders, thats all.
You might find a clue, like if a dowel is stuck in one and not the other, or a puck is stuck to one and matches a missing puck in the head, etc. But if no clues, don't worry about it.  IMO
« Last Edit: July 23, 2010, 06:01:53 AM by MCRider »
Offline mycb750k6
  • Rocketman
« Reply #2 on: July 23, 2010, 06:13:00 AM »
Thanks MC. I was reading the H-book on the topic and that's what he was asserting. Anyway I'll play with it and see what I can figure out. BTW, anybody here do valve jobs and or porting of these heads that you know of?
« Reply #3 on: July 23, 2010, 06:51:46 AM »
Mike: MRieck on the forum
Big Jay: APE
Buz: Dynoman
CycleX
Any local engine machine shop can do just a valve job. I'd stay with the above for porting as they are familiar with the CB750
I'm sure there are others here, I'm leaving out.
« Reply #4 on: July 23, 2010, 08:13:30 AM »
2nd vote for Mike he does beautiful work
Offline GammaFlat
« Reply #5 on: July 23, 2010, 08:23:23 AM »
Looking at your cam and where the towers meet it, you can kinda see a "fingerprint" wear pattern.  You may need a magnifying glass but I think you'll get there.  I have the same problem with a K0 engine and luckily or not so luckily, it's easy to tell what goes where  :o
K6
85 Goldwing
Offline mycb750k6
  • Rocketman
« Reply #6 on: July 23, 2010, 08:31:28 AM »
How does one find Mike: MRieck on the forum?
And thanks Gamma. I think I can now figure that out.
« Reply #7 on: July 23, 2010, 08:56:39 AM »
Go to members link in list of links and then page 238
Offline mycb750k6
  • Rocketman
« Reply #8 on: July 23, 2010, 04:44:41 PM »
I got it. The steel guides left in the rocker made it easy.
