Author Topic: cb550 putting the pistons/cylinders back together  (Read 1500 times)
Offline Wtrdog
« on: July 24, 2010, 06:34:13 AM »
ok so i got the bike apart (cb550) and I'm starting to put it back together.  any tips on getting the pistons back into the cylinders/jugs to make it easy?  this is the first time i'm doing this and I don't want to mess anything up.
Offline sniper1
  • SNIPER1
Re: cb550 putting the pistons/cylinders back together
« Reply #1 on: July 24, 2010, 06:51:22 AM »
wtrdog,
I just did this two weeks ago on my '77 cb550. Go get 4 hose clamps (1 for each Piston) that will be used to compress the rings. Start with the two center pistons (2,3) all the way up. Make sure the rings are offset like they call out for in the manuals. Cover the rings with the hose clamps and tighten down, tight but not too tight. Then place the head over the two middle pistons and start easing it down, You will probably have to tap with a rubber mallet or something around the head as it will be a little tough going. Once the rings are inside the head, simply remove the hose clamps from the two inner pistons. Continue tapping head down until you just make contact with the two outer pistons. Then crank the crankshaft to start the two outer pistons into the head. Start tapping down with rubber mallet. Crank the crankshaft more and keep tapping until the rings are inside the jugs. When far enough, unscrew hose clamps (these will be a little harder as there will not be much room to get them out, but it can be done), and tap jugs all the way down.
Once you start moving jugs down over pistons don't raise again. If you do you may have a ring pop free and will have to reset again, or run the risk of breaking a ring.
Have a buddy, wife, kid, dog or whoever you can to help out. Plus it helps to have someone there to cuss at and blame besides yourself.
Let me know if I can help with anything else, this is all still pretty fresh in my mind.
Offline Wtrdog
« Reply #2 on: July 24, 2010, 06:58:34 AM »
thanks that makes sense.  i'll get some clamps today and have a go at it. thanks again
Offline patricke9
  • SOHC4 #2037
« Reply #3 on: July 24, 2010, 08:42:37 AM »
Good tip, hopefully I too will be putting my '77 Cb550 back together next week after I get my parts back from the machine shop.
"I did everything by the seat of my pants. That's why I got hurt so much."
Evel Knievel
1978 Kawasaki KZ650
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: July 29, 2010, 12:49:14 PM »
Patrick: Curious as to what shop you used and how much they charged you. Did you do a complete rebuild, rings, bearings, everything? Thanks.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #5 on: July 29, 2010, 12:54:16 PM »
really only 2 shops in the area that actually know wtf to do with these old bikes.
twinline & northcityvintagehonda
http://www.northcityvintagehonda.com/servlet/Page?template=about
Offline Wtrdog
« Reply #6 on: July 29, 2010, 01:06:37 PM »
so that tipped worked, when I do it again this week I won't forget the gasket... :o
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: July 29, 2010, 01:35:21 PM »
I hear as much good as I do bad about Twinline. Thanks.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline patricke9
  • SOHC4 #2037
« Reply #8 on: July 29, 2010, 04:41:30 PM »
I am having John @ Autosport Seattle do a valve job, bead blast the cylinders & remove all the old gasket material.
http://www.autosportseattle.com
He quoted me $125 to cut new seats for the valves & bead blast the head.  They do machine work for most of the shops here in Seattle & I figured if they work on Ferraris & Jags etc they should do a good job on my stuff.  You can give him a call, they do work on bikes as well, there are usually a couple old BMW's, BSA's & a cool old Honda in the shop.  I stopped by on my way home today & he told me it would be done tomorrow.  Not doing a complete rebuild to mine, the bike only has 14,000 miles, only reason I took it apart was to change out the cam chain tensioner the previous owner screwed up.  After pulling the head found out the pistons & rings are fine, just 2 leaking valves.
Evel Knievel
1978 Kawasaki KZ650
Offline patricke9
  • SOHC4 #2037
« Reply #9 on: July 29, 2010, 04:47:06 PM »
Never had any dealings with North City, but have only heard good things from others about them.  Twinline on the other hand, not so good.  Ian is a nice enough guy & I have had a good time at the Dyno parties he puts on but would not let them anywhere near my bike.  Long wait, shoddy work etc.  Not to mention some bad blood between a couple friends of mine that helped him get the shop up & running & were very good mechanic's that got the boot to make room for much cheaper or non payed "interns".
Evel Knievel
1978 Kawasaki KZ650
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #10 on: July 29, 2010, 05:04:45 PM »
and the 4 O-rings around the bores  ;D
Another tip.  use wood blocks to steady your pistons as you slide the jugs down.  If you tried it without the blocks, you prolly had to say a few extra golf words to get 'em on straight.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
