Author Topic: On a different 750f....  (Read 939 times)
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
« on: July 24, 2010, 10:59:09 AM »
I'm cleaning a cb750f ('75) that I picked up.  It was sitting in a garage and the guy was moving....so fire sale!!! woo hoo!
but the throttle wouldn't turn, the carb wouldn't budge.  I pulled the carbs.. the throttle turns fine..the linkage that is.
So i'm full into the teardown ( still new to this .....but always having mad fun at it)...  the bowls had varnish.. but also...moss..yep green moss.. LOL
So I followed the previous instructions and pulled the bowls, jets, etc..  but I couldnt pull the air screw?  cause it looks like this.. just turns 360 max.
I think I found out what it was sticking.. #3 appears to be the one bugger..  I found this... what the hell happend here do you think?
heres what the other three look like.
« Last Edit: July 24, 2010, 11:03:11 AM by oldhondarider »
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Re: On a different 750f....
« Reply #1 on: July 24, 2010, 11:58:27 AM »
The plastic "cap" pulls off from the air screw and then it will come out. At least one of your slide/needle holders are toast,the one that is loose and crooked,needs repair before reassembly.Varnish will seize them right up if they sit for a very long period as you found out.
« Reply #2 on: July 24, 2010, 09:41:29 PM »
crap...  anyone got a replacement ?
