could be...but it depends where on your carb is it overflowing.
have you taken your tank off and drained it to see what comes out?
do the easy sht first.
![Cool 8)](http://forums.sohc4.net/Smileys/default/cool.gif)
even if youget it super clean, that sht is still in the carbs.
clean them really well, and while you're at it..
carb things you should check:
crack in overflow stand pipe
float height off
bad/stuck float valve
pinched bowl gasket
