Alright, #38 slow jets in, the needles turned one full turn out. Still at 130 mains. Carbs bench synced.
The engine's refusal to come down from cruising speed appears gone!
YAY!!
The idle is also gone!
BOO!!
I figured the title change to "A New Hope" would hit with the Star Wars fans as that seems to be where I am within this saga. I have a hope, but there still a lot of fight lest to go. - After a longer than normal test ride I was able to successfully get the bike to not have that nasty hanging idle with the above set up, but I also lost my idle. The bike would idle so low that it would stall. If I turned in the idle setting screw to where it would idle decently the hanging idle issue would come back. If I turned the thumb screw to just the right spot where it would just barely not stall out at idle, the idle would hang for a little bit when revved (10 to 15 seconds) and then drop back down.
Here is where my brain is at now:
- If the problem happens with the idle thumb screw turned further in, that means the slides are slightly higher up and the engine could be pulling fuel up through the mains as previously suggested with the extra vacuum from the 850 kit. With the slides where they need to be to idle correctly, there is not enough fuel to hold a steady idle due to the slow jets being so restricted at only one turn out. SO - by opening up the mixture screws another full turn, that will increase the fuel at idle WITHOUT raising the slides and keeping the mains closed off to the engine vacuum thus preventing the idle from hanging high.
Does that make sense?
       Am I way off base?
              Is anyone still reading this thread?
