Author Topic: oil on the fins.  (Read 1515 times)
Offline 78_SaltLick
  • Honda 1974 550
    • Custom Drum making
oil on the fins.
« on: February 19, 2006, 07:03:58 PM »
What does it mean when you get oil on one side of the fins on you engine? I got a 74 550, just noticed it today when i rode, it is fresh oil. Couple of weeks ago it wasnt there, i polished up the bike, did all the fins i saw no oil back then, now its fresh oil on all the lower fins on one side. Any ideas?
Gold sparkle is the place you outta be.
Offline scondon
  • Mmmm......tasty bugs
Re: oil on the fins.
« Reply #1 on: February 19, 2006, 08:20:46 PM »
Tach drive, valve caps, head gasket, valve cover gasket are just a few sources of oil leaks and it sounds like you have one. I'm not familiar with the 550 engine, but I am familiar with oil on the fins. Shouldn't affect anything but the cleanliness of your bike/clothes :)
« Reply #2 on: February 19, 2006, 09:41:53 PM »
Almost the entire top of the engine has fins and there are a lot of gasketed seams that can leak.  Perhaps if you were more specific we could better guide you.
Short of that, it is commond for the O rings near the head gasket at each end of the cylinder bank to become embrittled with the heat and lose their seal.
Offline bistromath
« Reply #3 on: February 19, 2006, 11:08:53 PM »
Whoa. Ten points for "embrittled". ;D
'75 CB550F
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: February 20, 2006, 01:17:57 AM »
In my experience with 500s and 550s, it's the cam end cover caps if the oil is on the cylinder head and Lloyd's embrittled o-rings if the oil is on the cylinder block.
First one is easy to fix.
Second requires the head off.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Zane
« Reply #5 on: February 20, 2006, 01:38:50 AM »
I bought my 400 last summer, and it had (and still has) a little oil weeping.  I had a similar experience as you - I cleaned the thing and then noticed a little oil here and there on the fins.  After 3 or 4 weeks of riding,  met an old timer who gave me some info I found helpful, but mainly I found it just made me feel better.
I can't vouch for the accuracy of what he said, but it made sense to me, when I thought about it.  He said that when those machines were sold new they came with a kind of a service schedule from Honda.  In that schedule, sometime during the first month or two (or around a thousand miles or so) the new owner was required to take the machine in to his dealer for service.  One of the things the dealer was supposed to do at that time was take off the top of the motor (whatever that's called - the head or something) and re-torque a series of long bolts which hold different parts of the engine together transversely.  This re-torque was pretty fundamental, and important.  It couldn't be done at the factory because the motor needed to run for a while in order for the procedure to be effective.  But once it was done at that particular time, the motor would be good from then on (barring undue maltreatment or abnormal stressing).
The catch, according to this guy I spoke with, was that some owners never took their machines in for the servicing, and some dealers didn't perform the re-torque properly or at all.
So over the years i imagine some of the machines which didn't get that service item performed probably didn't age under as ideal a circumstance as they would have if they would have, had the particular service been performed.
This man had had Honda 4's of different sizes for about 35 years when I met him.  He went on to say that a little weeping, as he called it, is normal for the 4 cylinder Honda engines.  Not a lot, but a steady little.  He went on to explain the difference between an oil leak, and this little "weeping" business.  My weeping comes and goes, depending on how much and how hard I ride.  But it's definitely weeping, not leaking.  I just wipe it off (although I do watch closely the location and intensity - so I can jump on it if it moves up to a bona fide "leak").
I mention this not because I think it's particularly helpful to you, but because it helped me understand the nature of these great old engines a little better.  It certainly made me feel a lot better about wiping away evidence of oil as well - wiping it away before I was told that a little weeping was "normal" (or at least that it wasn't a terrible thing at the degree to which it was happening in my engine) made me feel like I was just denying a real problem.
I suppose there are other old timers who might say this is all b.s., and that these engines are not supposed to leak at all, under any circumstances.  But it makes sense to me.
Once I get comfortable enough to actually go inside my engine (next winter, most likely) I'll be able to check the torque of the bolts this old chap mentioned.  But since I spoke with the guy I've put almost 20,000 kilometers on the machine and it still runs like a dream.  I change the oil religiously (maybe even too often) and I estimate, depending on the intensity with which I ride, that it might "weep" a dozen drops or so, between changes.  (Hard to calculate the amount because the oil never drips (that would be a leak, I guess) it just shows up on the fins.  If I don't wipe it away it collects dirt and grime quickly, and then it looks a lot worse than it is.
Sorry for the over-long post.  Just thought I'd tell you that little story, for whatever it's worth.
Best of luck,
Z.
Offline 78_SaltLick
  • Honda 1974 550
« Reply #6 on: February 20, 2006, 04:32:46 AM »
well thats all good news i suppose. My bike also has an oil leak, one or two drops appear under the bike when it sits for a week or so. i think this is coming from the front sproket, i cant tell. Ive heard that also was normal..... :)oh well i keep checking the oil and it never goes down on the dipstick, it cant be that bad whatever is going on. Thanks guys.
Offline jdpas29
  • my bike is 100% sandcast!!
    • My band = white bread
« Reply #7 on: February 20, 2006, 04:34:27 AM »
awwwww!!!   :D  so you just get to wipe away your little bikey's tears   :'( :'( :'(
teee heee!   :D
cars are gay.
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #8 on: February 20, 2006, 05:09:33 AM »
I had a bit of oil weeping out where the head mates to the cylinders on my CB 500 K2.  I re-torqued the head bolts and the oil leaks completely vanished.  I found most of the bolts required some turning to get up to spec.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
« Reply #9 on: February 20, 2006, 05:30:34 AM »
Sorry to burst your bubble Zane but Honda NEVER specified a re-torque at any service interval on motorcycles. Cant say about cars or power equipment but definitely not bikes and i worked at a main dealer in UK for many years. That said on the 500/550 it might be worth a try if the leak starts soon after a rebuild but with a 78 thats probably never been touched i can just about guarantee that the head "O" rings is weeping due to hardness/heating-cooling/age
Offline n9viw
  • Floyd, '76 CB550k
« Reply #10 on: February 20, 2006, 12:02:20 PM »
My 550 has "weeped" (hell, a weep is just a slow leak to me, call a spade a spade) from the cam end caps, from the cam end cap brackets (supposed to have a copper washer on one side and an aluminum washer on the other side of the bracket), and from the oil tower o-rings. Replace all o-rings with Viton rubber, and replace the cam end cap bracket washers with both copper, or both bronze (did bronze on mine). Not had a leak since. ;)
Nick
'76 Honda CB550k
'73 Honda CB750k
Offline jaknight
  • ....Round Town Ride......
« Reply #11 on: February 20, 2006, 02:49:26 PM »
HEY ZANE---------->
   That is an interesting story.  Somehow, if not Biblical truth, as one posting below yours does say, it does have a Salt of The Earth true ring to the "Old Man's" recount.
   ~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
