Author Topic: Where can i get a brass plug for a Mikuni carb?  (Read 6665 times)
Offline mgbgt89
« on: July 31, 2010, 03:17:46 PM »
I'm working on a Suzuki Bandit today, doing a carb rebuild. One of the brass plugs is missing from one of the carb bodies. PO had jammed a rubber plug in there holding it in with gasket sealer, which blocked flow through one of the passages through the carb. Where could i get one of these? Should i just take it to a machine shop and have them make a plug?
Offline mcpuffett
Re: Where can i get a brass plug for a Mikuni carb?
« Reply #1 on: July 31, 2010, 03:26:53 PM »
bike breakers maybe?
Offline 77cafe750
« Reply #2 on: July 31, 2010, 03:33:02 PM »
i will dig in my stash tonight and see if i have any
live like an outlaw and love like an angel
crash
blacked out gauges rock
http://forums.sohc4.net/index.php?topic=67710.0
Offline mgbgt89
« Reply #3 on: July 31, 2010, 03:40:52 PM »
I don't even see how to remove that plug in the first place. It's just a press fit, and its a blind hole so you cant really press it out. I played around with another carb trying to blow it out with compressed air and it wasn't happening.
Offline 77cafe750
« Reply #4 on: July 31, 2010, 04:39:43 PM »
i just have a bunch of stuff like that in the garage for rebuilds and other purposes
crash
Offline mgbgt89
« Reply #5 on: July 31, 2010, 04:45:53 PM »
How do they come out?
Offline kirkn
« Reply #6 on: July 31, 2010, 05:03:10 PM »
Maybe the PO drilled it out, thinking he was drilling out the cap that the manufacturer fits over the idle-air screw?
How 'bout making a little tin cover that's just slightly larger than the OEM brass plug and super-gluing or even JBWelding the cover onto that little 'shelf' that you can see in the first picture.  Something to cover the opening where the brass plug used to fit, but not plug up the internal passages?
Offline 77cafe750
« Reply #7 on: July 31, 2010, 05:09:25 PM »
i get them out by drilling them and then replaceing them
crash
Offline mgbgt89
« Reply #8 on: July 31, 2010, 05:30:34 PM »
So where do you get your replacements?
Offline mgbgt89
« Reply #9 on: July 31, 2010, 05:33:22 PM »
I was actually thinking about using a shell casing for this exact purpose. I would think that would work pretty well.
The PO made his own caps out of caulking for the air screw. I don't mind Jerry-rigging things on my own bikes, but working on friends bikes i always want to do it right, or at least so it looks right  ;)
Offline mgbgt89
« Reply #10 on: July 31, 2010, 05:34:02 PM »
JB weld is gasoline proof correct?
Offline 77cafe750
« Reply #11 on: July 31, 2010, 06:06:33 PM »
my grandfather makes them for me  ;D
crash
Offline lordmoonpie
    • Moonpie
« Reply #12 on: August 10, 2010, 04:10:56 AM »
Allens Performance in the Uk will do them...they have a website
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline tomkimberly
« Reply #13 on: August 21, 2010, 06:36:27 PM »
