Author Topic: Engine colors...POST YOURS HERE  (Read 4350 times)
Offline SKTP
« on: August 03, 2010, 10:24:43 AM »
I am hoping people will post there painted engines here. I am currently painting mine and have done the block matte black and the cases matte aluminum...I was going to do the head aluminum too but my friend insists that "nobody would ever do that and it will look stupid with a black block."
If you know of an engine with a black block and silver head, I'd love to see it...thanks for all your help
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=vol99fkvm8d56pj0ufamg2dls7&/topic,60973.0.html
Re: Engine colors...POST YOURS HERE
« Reply #1 on: August 03, 2010, 10:35:41 AM »
it vill look great that vay..silver black silver...dont make top black..
i have glass blast bottom make silinder black and polish valve kover..on my 400..takes some pics soon...
i hate all this v-w.... vords
EverettShadowbrook
« Reply #2 on: August 03, 2010, 11:23:28 AM »
Here's one with the paint scheme you are thinking of. It looks OK.
KingCustomCycles.com
« Reply #3 on: August 03, 2010, 11:23:50 AM »
Here you go.....
« Reply #4 on: August 03, 2010, 11:28:54 AM »
Offline ev0lve
« Reply #5 on: August 03, 2010, 12:09:18 PM »
Well, I don't think it looks stupid  ;D
Offline tweakin
  • tear down
« Reply #6 on: August 03, 2010, 12:11:52 PM »
Here is a pic of my 750.  The paint is the reverse of what you did.
This is the engine in my 400twin
Offline SKTP
« Reply #7 on: August 03, 2010, 12:14:58 PM »
That looks amazing...is it paint of powder coat?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline ev0lve
« Reply #8 on: August 03, 2010, 12:16:56 PM »
Yeah! Is there a build thread?
Edit:
Found it I think
http://forums.sohc4.net/index.php?topic=68722.0
« Last Edit: August 03, 2010, 12:21:40 PM by Iggy »
Offline tweakin
  • tear down
« Reply #9 on: August 03, 2010, 12:22:06 PM »
Thanks guys, I appreciate it.  The engine case is painted in High temp satin black and the jugs and Head were painted in high temp NU aluminum, both VHT.  All the covers were powdercoated in high gloss black.
The build thread is here;
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« Reply #10 on: August 03, 2010, 12:37:38 PM »
Duplicolor Cast Coat Iron (3 coats, with etch primer underneath), with polished fins and case covers.  Would have done the heads black with polished fins, but I was too lazy to tape everything off and spray again!
http://forums.sohc4.net/index.php?topic=70938.0
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #11 on: August 03, 2010, 12:52:04 PM »
Offline jacquesleclochard
  • If Tin Can do it, you can do it!
    • Tin Can Customs
« Reply #12 on: August 03, 2010, 02:51:51 PM »
Here you go.....
Man, your bikes are the best. So awesome. This is the Father, right?
Offline Ichiban 4
  • "Ichi"
« Reply #13 on: August 03, 2010, 03:38:02 PM »
This may be a little off topic..but this subject remends me of a whole series of tests that were done on engine color (cylinder & head color particularly)..back in the early 1960's..when most motorcycle engines were air-cooled..and temperatures/overheating was a continual concern.
The bike I was riding in particular..an Ariel Square Four..tended to have overheating issues with the two rear cylinders..tucked behind the front ones.  Factory engine color on those bikes was silver/aluminum..but they found that by painting the cylinders..sometimes the heads..BLACK..that the running temps were reduced by 10 to 15 degrees F. That was enough to remedy the pre-ignition problems with the two rear cylinders on those bikes.
I remember also..that other bikers would paint their heads and cylinders darker colors..to have the engines run a little cooler (this was in So. California..in the Summer..where ambient temps were well over 100 F.) If I remember correctly..the reason the darker colors ran/run cooler..is that it allows for faster heat dissipation to the surrounding environment.
Nowadays..with oil/liquid cooled engines..I guess this isn't so much of a concern..but it still seems useful to know..for these old Honda air-cooled engines.
Ichi
« Last Edit: August 03, 2010, 03:44:06 PM by Ichiban 4 »
Al Summers
Present: '77 550K
« Reply #14 on: August 03, 2010, 03:48:29 PM »
Starting in the 40's and before, aircraft (air cooled) engines had the cylinders painted black for exactly the reasons you describe.  The Piper Cub is the most obvious example with an all yellow paint scheme and those prominent black cylinders sticking out of the cowl.
Offline SKTP
« Reply #15 on: August 03, 2010, 04:00:01 PM »
Hrmmm, with this new information...I think I will go black and not come back!
Any tips on sanding the side of the fins to silver? I hope to tape as little as possible in the future....
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #16 on: August 03, 2010, 04:06:21 PM »
I sanded the fins with 40 grit, 110 grit, all the way down to a 800. Now they were straight and polished. The head was painted without tape. Once the paint dried I dabbed a rag corner in Varsol and wiped the fin edges. and Ta Da....you have polished fins with a painted head.
Offline KB02
« Reply #17 on: August 04, 2010, 05:59:07 AM »
I went with something a little different than black and silver for my engine:
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Cuts Crooked
  • Cowboy Biker
« Reply #18 on: August 04, 2010, 06:54:14 AM »
Dude!!!! Think "old Triumph"....the coolest looking bikes ever made, with that exact color scheme! 8)
(apologies fer mentioning them here...but I truely LOVED my 72 Strumpet, she was a 650 Tiger, with a 750 upper end, TT pipes, 6" over forks, neck raked, shorty apes, metallic blue tank & fenders with white stripes......sigh)
Cuts Crooked
CB 750K8
Old Bikes 'n Old Guns are my first two loves :)
Offline Doctor_D
« Reply #19 on: August 04, 2010, 07:03:36 AM »
Here's mine:
Take care,
David
1978 CX500
1971 Norton Commando
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #20 on: August 04, 2010, 07:07:47 AM »
if you paint it black, then def. polish the fins!  just take some scotch print and rub off the paint.  it doesn't have to be shiny, but it sure will make the motor pop!!
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #21 on: August 04, 2010, 11:47:15 AM »
cast coat iron lover, black jugs, cast coat steel valve cover
wrinkle black on side covers, kicker...
Offline 78CB750CAFE
  • I'm not really an
« Reply #22 on: August 04, 2010, 11:47:57 AM »
that looks better
Offline goaarongo
  • zen and the art of angle grinding
« Reply #23 on: August 04, 2010, 01:22:06 PM »
I'm just getting ready to drop this into my frame.  My 2 cents on polishing fins is to do all the sanding and polishing before you paint.  Then paint the whole part and the paint is fairly easy to remove from the finished surface.
Offline SKTP
« Reply #24 on: August 04, 2010, 02:02:12 PM »
Thanks everyone!  ;D
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
