Author Topic: Is gasket cement recommended for the oil pan gasket?  (Read 3707 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: August 07, 2010, 12:54:29 PM »
Or is a new gasket good by itself?
Offline Frankenkit
  • Industrial Strength
Re: Is gasket cement recommended for the oil pan gasket?
« Reply #1 on: August 07, 2010, 12:56:00 PM »
I'd add a thin schmear of gasket goo.  Not enough to go anywhere it shouldn't, but just enough to help make sure the oil pan doesn't weep.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: August 07, 2010, 01:08:06 PM »
Some do, some don't.  I don't and have never had one leak on me.
saw750
« Reply #3 on: August 31, 2010, 05:34:26 PM »
lol i am at the same point in my rehab and have the same question ie gasket cement on the oil pan gasket??
i was always taught to rarely ever use gasket cement...
when i purchased the new gasket from the dealer they said "no cement" but my "mentor" - who owns a cycle shop and has been wrenching on cycles since before i was born - says "yes cement" - he taught me the ways of old triumph (i dont know if that is good or bad..lol ; ) he says RTV
so i am curious which is correct?
i can tell you that the original gasket looked as if it did have a thin coat of gasket cement applied to it at one time..
saw
« Last Edit: August 31, 2010, 05:36:19 PM by saw750 »
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: August 31, 2010, 05:47:06 PM »
If both surfaces are clean and true, you shouldn't need any. Another personal opinion, of course.  ;)
Offline Alan F.
« Reply #5 on: August 31, 2010, 05:50:04 PM »
+1 for clean surfaces and a dry gasket.
Online scottly
« Reply #6 on: August 31, 2010, 06:08:53 PM »
+2
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: August 31, 2010, 06:16:15 PM »
+3
BUT, in his book Hondaman recommends sealing the heads of the oil pan bolts with sealant, to prevent them from leaking.  Seems like good advice.
mystic_1
- John Augustus Shedd
saw750
« Reply #8 on: September 01, 2010, 09:15:19 AM »
yep sounds like the the plan ie no cement
however..this is interesting..lol
http://www.dansmc.com/gaskets.htm
Offline wrenchmuch
« Reply #9 on: September 01, 2010, 09:39:29 AM »
If you do use a sealant with gaskets don't use RTV . It seems to be more prone to getting loose in the engine then other sealing compounds . Three bond 1104 or equivalent THINLY applied Just before assembly if you think you need it .
CB750K1
CB750K4
Offline Skunk Stripe
« Reply #10 on: September 01, 2010, 10:07:26 AM »
No cement here either. Nothing on the bolts. no leaks at all all.
« Reply #11 on: September 01, 2010, 10:49:24 AM »
Your dansmc.com article says stay away from silicone, so if the RTV is silicone, I would stay away. On the CB750s, thats a good way to twist a cam. You would want to use the "elephant snot" type that stays semi flexible and spreads very thin.
He says use some grease. I'd always been taught to use a little motor oil between the fingers. Sounds like the same approach.
Finally, if you use cement just cement one side. The gasket will stick to that side hopefully if you have to take it off and you can reuse it, again hopefully.
Otherwise, dry should be fine.
