Author Topic: What is the smallest van to fit a CB750 in?  (Read 2348 times)
Offline jacquesleclochard
  • If Tin Can do it, you can do it!
    • Tin Can Customs
« on: August 08, 2010, 11:06:51 AM »
Hey gang. I am interested in buying a car. It'll be my first four-wheeler.   :-X
For me it would be a good idea to buy a van, type transporter, since my CB750 tends to break down a lot. Next to that, I like to do ocasional surf and snowboard trips. Extra storage space is a winner!
Now I do not want to drive a bulk, but the smallest van that would fit a CB750. What would you suggest? Like I said, this is my first car, and I know jack all about cars. So, where to start looking?
Offline dhall57
Re: What is the smallest van to fit a CB750 in?
« Reply #1 on: August 08, 2010, 11:18:07 AM »
I know for sure the 750 will fit in the Dodge and Chrysler mini vans. But of course the rear seat or seats must come out and even after this its still a tight fit.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Johnie
« Reply #2 on: August 08, 2010, 11:22:38 AM »
Well, last fall hoodleyhoo and I got a CB750K6 in my 99 Dodge Caravan. You have to do it from the side door as it is bigger than the rear. I also hauled a K4 in it from Milwaukee. It was tight, but we did it. Then we used the floor seat brackets as tie down anchors. Worked good...not sure you could go much smaller for a van to haul a 750 than this Caravan. Hoodleyhoo has a pic maybe he can post.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline ieism
« Reply #3 on: August 08, 2010, 11:45:21 AM »
We have a Chrysler mini van at work, and i'm sure it would fit a 750. But the amount of gas it uses is ridiculous. Bear in mind that gasprices are insane where we live. And roadtax for these cars is enough to make you cry.
If you want an economical option, I would buy a normal van without seats or windows in the back (grijs kenteken). Sure they are bigger, but you'll get used to parking it pretty fast.
We also have two VW vans, one brandnew and the other 10 years old. Everyone that drives it is in love with the older one. They are cheap to run, I drove it to Italy on one tank of diesel. And they have a lot of power too, they cruise at 150 km/h all day.
Perfect for your surfing trips, throw a matress in the back and you've got a place to sleep too.
---cb550---
    • Tin Can Customs
« Reply #4 on: August 08, 2010, 12:08:26 PM »
Hey man, thanks for the input! What type of Volkswagen am I looking at? The older one sounds good, I have a knack for older cars. And you mentioned het Grijze Kenteken. How exactly does that apply and what are the benefits?
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: August 08, 2010, 12:16:57 PM »
A CB750 will fit in an old Toyota van.  That's what I drove mine from Denver to Oregon in when I bought it.
Offline ryder60
« Reply #6 on: August 08, 2010, 12:30:57 PM »
I used to haul my FZR400 to the track in my Plymouth minivan.  I had to push the seats as far forward as they could go, too far forward for my 5'10", and the front wheel had to go up between the seats.  I'd get a van that was definitely big enough.
Offline Kevin D
  • SE Michigan
« Reply #7 on: August 08, 2010, 01:14:41 PM »
Put a few bucks in the CB and you will be way ahead. ;)
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline fullofdays
  • Broken
  • good old age, old and full of days - Gen 25:8
« Reply #8 on: August 08, 2010, 03:09:13 PM »
ford transit connect -- For the Win!  but used ones are hard to find and they are spendy :)
chevy makes an uplander kitted out for cargo purposes that has that minivan look.  Put some presidential limo tent on the windows and nobody would be the wiser.
http://washingtondc.craigslist.org/doc/ctd/1887530395.html
Offline tsp37
  • I don't want a pickle . . .
« Reply #9 on: August 08, 2010, 05:16:53 PM »
I can roll my 650 into the back of my long W/B GMC Safari.  I have to remove the mirrors, release the air from the front forks and then pull them down with a ratcheting strap.  The bike barely slips under the rear A/C.  The bike could not roll in straight - only the angle of the ramp effectively reduces the handlebar height to clear the overhead A/C.
The rear seats are normally fixed to four points in the floor, and these work well for tie down straps.  I then have room on either side of the bike for the two pieces of my homemade 2x4 & plywood ramp.
Offline hoodellyhoo
  • CB350F
« Reply #10 on: August 08, 2010, 06:13:00 PM »
Here are the pics johnie was talking about. Just had to take the mirrors off.
Offline 74cb750
« Reply #11 on: August 09, 2010, 05:21:56 AM »
I hauled many bikes in my Plymouth minivan, but I think
the small 4 cyclinder engine couldn't take the strain. It died.
Laugh at least once a day.
Life  $ucks, then you die.
Offline GammaFlat
« Reply #12 on: August 09, 2010, 05:47:54 AM »
'01 Honda Odyssey.
K6
85 Goldwing
