Author Topic: Wiseco 836cc kit: Barrel gasket question.  (Read 1190 times)
Offline eshumaker
« on: August 11, 2010, 01:43:11 PM »
I am installing a Wiseco 836cc kit, and it came with a copper and a cardboard gasket. So.. first question, the copper is the barrel to the crankcase, right?
That being correct, I am wondering if I should use any form of gasket sealer, or if the copper gasket is sufficient? I checked the surface with a straightedge, and it really looks pretty flat... ???
Thanks for the help!
Erik
1976 CB750 (basket case in progress)
1979 GL1000 Goldwing (runner)
1983 CB750 Nighthawk (basket case)
2004 Yamaha R6 (commuter)
Offline I Zombie
Re: Wiseco 836cc kit: Barrel gasket question.
« Reply #1 on: August 11, 2010, 01:58:48 PM »
I'd guess the copper gasket would be head to cyl & the fiber one would be the cyl to case
78 CB750K
Offline eshumaker
« Reply #2 on: August 11, 2010, 02:00:13 PM »
Ok, that makes sense. Would you put any gasket sealer on the head gasket? Or should the copper be good enough?
E
Offline I Zombie
« Reply #3 on: August 11, 2010, 02:12:52 PM »
just spray copper coat but that would be it
78 CB750K
