Author Topic: internal gas tank restoration  (Read 1575 times)
Offline Vintage SM
« on: August 11, 2010, 03:03:05 PM »
what kind of products and processes have some of you used to restore and seal the inside of your metal gas tanks? This tank is already somewhat clean, but still has some surface rust.
« Last Edit: August 12, 2010, 11:16:25 AM by Vintage SM »
Offline BeSeeingYou
Re: internal gas tank restoration
« Reply #1 on: August 11, 2010, 09:57:13 PM »
Do a search as there are several threads about this in Tricks and Tips .  No need to go over it again on a new thread.
« Last Edit: August 11, 2010, 09:59:02 PM by srust58 »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: August 11, 2010, 10:19:19 PM »
srust58 has the last word on these things, so don't try and sway him with bribes. ;)
Offline BeSeeingYou
« Reply #3 on: August 12, 2010, 03:37:16 PM »
well hold on there seaweb.....how much we talkin about? ;D
Offline Vintage SM
« Reply #4 on: August 12, 2010, 05:00:51 PM »
It's cause I've only got 1/4 the cylinders.... I did a quick search and found one positive method, I was just hoping on a few other tips anyone might have.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #5 on: August 12, 2010, 06:59:53 PM »
I use molasses with water 3-1 to de-rust my tanks. A few rocks and 5 days of swirling from time to time. ;)
Offline BeSeeingYou
« Reply #6 on: August 12, 2010, 09:40:44 PM »
If you are in a hurry muratic acid is very quick.  It has nasty fumes so do it outdoors and make sure you have removed the petcock regardless of how you do it.  Rinse the whole tank quickly with water followed by with a few tablespoons of baking soda in a quart of water, slosh it around on all surfaces even if you had the acid only in the bottom of the tank.  The fumes alone will leave a residue that will cause flash rust unless neutralized.  CLR will work to remove light surface corrosion or flash rust and it is not so nasty to work with.  Again you have to neutralize it afterward, same with The Works toilet bowl cleaner.  Unless your tank is compromised by corrosion I would not use a tank liner.  They fail all to often more than likely caused by poor application by folks who cut corners and don't follow instructions to the letter.  The idea that you can put a liner over corrosion in a tank is absurd to me.  Vinegar or molasses work too if you don't mind the extra time and have the benefit of not being nasty to work with.  There is Evaporust and electrolysis too.  Take your pick.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #7 on: August 12, 2010, 10:02:04 PM »
Or you could do it in your kitchen, and then pour it out into the garden ;D ;D ;D ;D ;D ;D
Life really isn't a race ;)
Offline Vintage SM
« Reply #8 on: August 13, 2010, 02:16:08 PM »
sweet guys, thanks for the tips!
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #9 on: August 15, 2010, 06:50:55 AM »
Look for a post by me where I link to a guy who used electrolysis to remove rust, if you don't want to go the chemical or sandblasting route to get rid of that rust.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Bwana
« Reply #10 on: August 16, 2010, 11:33:43 PM »
Electrolysis method seconded.   All you need is a battery charger, some water, baking soda, a metal rod, and a plastic tube with holes in it that fits over the rod.    And a bit of time.  No shaking the tank and no dealing with chemicals.
Here's a good link for the process in general.
« Reply #11 on: August 16, 2010, 11:58:02 PM »
Add another vote for electrolysis.  Unlike the acid methods, it just removes the rust without dissolving the metal.
Offline No1Banana
« Reply #12 on: September 01, 2010, 10:17:32 AM »
3rd'd for electrolysis. Especially if there's very little rust inside. Just make sure the metal rod doesn't touch any of the metal in the tank, otherwise it won't work.
Bwana
« Reply #13 on: September 01, 2010, 12:35:02 PM »
That's what I used the plastic tubing for.   Get a piece of tubing that is much larger inside diameter than the metal rod &  punch a bunch of holes in it.   Then you don't need to worry about shorting it out on the inside of the tank.
