Author Topic: CB750F seat on a CB750K  (Read 1683 times)
Offline crousos
« on: August 12, 2010, 04:26:36 PM »
Is there anyone here that has done  it? any tips? easy ? hard?
Constantin
Re: CB750F seat on a CB750K
« Reply #1 on: August 12, 2010, 04:31:05 PM »
Constantin
I wouldn't bother, the "F" frames are longer at the back than the "K" frames and have a totally different seat...
Offline crousos
« Reply #2 on: August 12, 2010, 06:08:21 PM »
Thanks, any other ideas for a seat the bike is otherwise more or less stock.
« Reply #3 on: August 12, 2010, 06:14:22 PM »
I would just ask around here. There are heaps of cafe guys here that don't use the stock seat so it shouldn't be too hard to get one.....
Offline crousos
Re: CB750F seat on a CB750K some pictures ..
« Reply #4 on: August 12, 2010, 06:28:35 PM »
Here it is after 4 months of of cleaning a tune up and some minor  and some minor upgrades and repairs.
« Last Edit: August 12, 2010, 06:35:41 PM by crousos »
Offline climbingaz
« Reply #5 on: August 13, 2010, 11:54:05 AM »
Don't quote me on this, but I think the '77 & '78 k models had a slightly longer frame than the earlier models.  So it might be worth a shot to try an F model seat.  I have no idea about the mounting tabs though.
Offline brewsky
« Reply #6 on: August 13, 2010, 05:01:00 PM »
Constantin
Why change that seat?
It looks in good shape and in my opinion is the most comfortable motorcycle seat ever designed.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: August 13, 2010, 07:16:31 PM »
I have both a 78' CB750K and a 78' CB750F and the F seat definitely uses a different hinge. I'm sure an F seat could be mounted to a K frame but some modification/fabrication would likely be required.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
bollingball
« Reply #8 on: August 13, 2010, 08:38:37 PM »
Why are you doing this want a new look? or confort is that a 77 or 78 I have a78k it has Travelcade want to trade
Offline crousos
« Reply #9 on: August 14, 2010, 12:38:38 PM »
Mainly for looks, I just like the way that the F seat looks better and hopefully I can loose some height also.
Offline octagon
« Reply #10 on: August 14, 2010, 01:16:49 PM »
i've done that on a 76 750k - because i needed a seat and had access to an f type seat pan and foam - it was interesting in a way, but not really worth all the trouble - you have to do lots of work on the pan.
« Last Edit: August 14, 2010, 03:54:33 PM by octagon »
Offline UPHOTO
« Reply #11 on: August 14, 2010, 02:51:46 PM »
Constantin, that would be an interesting project that's for sure.
Let me know if you still want my seat, you might want to try it with a seat that needs to be recovered instead so that if it doesn't work then it doesn't cost as much.  My seat is pretty much brand new.
Offline BeSeeingYou
« Reply #12 on: August 14, 2010, 04:34:12 PM »
I have seen a few K bikes with the F seat/cowl and gas tank.  Don't know the particulars but here is a pic of one.
« Reply #13 on: August 14, 2010, 10:04:07 PM »
I have a 77K and 77F to look at, the seat mounts and seat lengths are different, the 77-78 K frame appears to have the extended rear frame of the F models.
