SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
oil plug behind alternator cover
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: oil plug behind alternator cover (Read 933 times)
parm
Full Member
on:
March 16, 2011, 04:48:42 PM »
ive been having a problem with my oil plug behind the alternator cover. everytime i kick the bike over it pushes out. ive replaced the o-ring. its like pressure builds up in the crankcase and just pushes it out. anybody seen this or had the same problem. the bike is a 71 cb500
Logged
TwoTired
Really Old Timer ...
Re: oil plug behind alternator cover
Reply #1 on:
March 16, 2011, 04:54:27 PM »
Huh ?
It plugs the oil gallery. Should have 40PSI or above when the engine spins.
Does it come out when the alternator cover is installed?
Logged
parm
Full Member
Reply #2 on:
March 16, 2011, 05:46:37 PM »
yeah i have the alternator cover installed. its very frustrating and messy. is there something on the alternator cover that pushes on it to keep it in place?
Logged
bwaller
Reply #3 on:
March 16, 2011, 06:13:38 PM »
There should be a "pin" as part of the plug to locate it against the cover and keep it from pushing out. Has this been damaged, or is the plug in backwards? The outer edge of the oil gallery can be very sharp & damage o-rings when re-installing.
Logged
parm
Full Member
Reply #4 on:
March 16, 2011, 06:35:00 PM »
thanks bwaller it was in backwards. owner created mystery solved.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
