Author Topic: '78 CB750 rear wheel and hub on a '74 CB750?????  (Read 1539 times)
Offline katmol
« on: August 14, 2010, 03:05:30 AM »
Will it just swap? If not, what will I need to make it fit?
'74 CB750K Tracy Project
'76 "Modified" GL1000
'77 CB750A Blue
'77 CB750A Red
'79 CM400A Hondamatic
'81 CM400A Hondamatic
"Gone but not forgoten."
'76 CB750A Muscat Green
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
'78 750K Black Dresser
Re: '78 CB750 rear wheel and hub on a '74 CB750?????
« Reply #1 on: August 14, 2010, 08:21:31 AM »
Use the 77/78 wheel, with your sprocket holder& inner spacer. Use your original outer spacers, then it should fit..
ie use only the wheel, or wheel and brake, but not the sprocket side (has more offset)
Offline GammaFlat
« Reply #2 on: August 14, 2010, 01:39:58 PM »
On a related topic, I'm trying to put a K7 engine in a K6.  It appears to me that if you mount a 530 sprocket on the K7 engine, your front sprocket is about 10mm or 3/8ths of an inch outboard relative to where the K6 engine would have put it.  It seems that CycleX sells a 10mm (20mm as well) offset rear sprocket which would work.  Is there another way to do this?   Spacers?  Change the whole swing arm and use a K7 carrier?
K6
85 Goldwing
Offline hondaface75
« Reply #3 on: August 14, 2010, 02:05:28 PM »
Im curious about the offset sprocket too as I'm putting a K5 sprocket on a K7 motor and frame (its brand new and what I have). Is this possible? Will I have to mill some of this sprocket off?
Offline GammaFlat
« Reply #4 on: August 14, 2010, 02:59:12 PM »
I think our issues are little different.  When you say "K5 Sprocket", I assume you mean a 530 as opposed to 630.  The 530 sprocket is a little "fatter" where it goes on the shaft.  I have heard that people just tighten down the center bolt and are okay.  If you want some float (which I think was intended for the 530 setup), you can "build out" where the bolt and washer tighten down with one or more washers.  The way the K7 with 630 setup works baffles me a bit because I believe the sprocket is intended to be held down tightly to the shaft with the single bolt and washer.  The 530 seems to be engineered to float a bit.
My problem is that I'm out of alignment.  Your alignment should be perfect.  If you look at the following picture (530 left and 630 right), you'll note that the "height" of these two sprockets is different - 530 being taller.  They are both "engine side down".  The teeth centers (also center of chain) line up perfectly.  So, I think you're okay. The extra height of the sprocket is all on the "outside" of the center-line of the chain.
I'll wait for others to comment :)
« Last Edit: August 14, 2010, 03:18:49 PM by GammaFlat »
K6
85 Goldwing
« Reply #5 on: August 14, 2010, 09:10:37 PM »
Simply put..regardless of if you run 530 or 630 chain;
77/78 motors have a longer sprocket shaft.
 and a sprocket carrier (AND INNER SPACER)
with more off set (to match shaft on motor)
 If you are running a late motor, you have 2 choices;
 Run the correct sprocket holder and spacer
 or...
 shim out your sprocket on an earlier sprocket carrier.
 Its that simple..
Offline hondaface75
« Reply #6 on: August 15, 2010, 03:18:02 AM »
So I'm in the clear then, No milling, just shimming. Perfect. Thanks for the info guys.
