Author Topic: RH starter switch CB750F 1976  (Read 2526 times)
Offline Mr. Mac
« on: July 26, 2010, 02:30:27 PM »
My starter switch is giving me grief. How to replace this complete RH switch? Where to find one and tips?
Mr. Mac
Offline BeSeeingYou
Re: RH starter switch CB750F 1976
« Reply #1 on: July 26, 2010, 04:59:23 PM »
My switch imploded into several pieces so I picked up a new right hand control from www.babbittsonline for $95.  The individual switch is not available.  A used one is a waste of time as it too will fail in time.  You will need to remove the gas tank and disconnect the throttle cables from the carb linkage.  The electrical connections are in the junction box on the frame above the headers.  I attached a string to the old wires in the handlebar as I pulled them out and used it to pull the wires of the new control into place.
Offline Steve F
« Reply #2 on: July 26, 2010, 08:10:15 PM »
I was able to fit a miniature pushbutton switch into the stock switch location without too much trouble since the stock one was in 50 or so pieces.
You can probably get one that will fit from Radio Shack.  You need a SPDT "MOMENTARY" pushbutton.  It doesn't look like the factory original by any means, but on the bright side, it's cheap and easy to do.
Offline Bodi
« Reply #3 on: July 27, 2010, 07:41:26 AM »
I bought a selection of little switches to replace the original bits of plastic dust and such I found in the housing.
There's not much room.
No SPDT switch rated for the headlight current I could find would fit. No decent quality switch of any type I could find would fit. I got an Asian made el-cheapo radio Shack or equivalent SPST switch with open spring metal parts in back, quite small and rated OK for the solenoid current. It fit in the housing with no mods, the threaded part fit nicely in the button hole with just enough thread sticking out for the nut to fit. I connected the headlight to bypass the old shutoff-while-starting function and have seen no difference for its loss. This has worked for many years. Recently I learned that the button can pull out. After finding the button and asking my son not to pull it out again, it continues to work fine.
Offline MacM2010
  • Nobody Special
« Reply #4 on: August 31, 2010, 06:27:43 PM »
Sorry to bump a dusty thread... Bodi - to bypass the shutoff-while-starting function, which wires did you jump?  I searched around and read that they are in the headlight bucket... what did you do?
Thanks,
Mac
One day, I will put up a signature.
Offline Mr. Mac
« Reply #5 on: September 05, 2010, 06:50:55 PM »
Well I just disconnected the wire to the starter relay for now and am kick-starting.
My buddy will be looking into a real fix in September.
Offline rangelov
  • The Dual Disc Conversion Speedometer Driver
« Reply #6 on: September 06, 2010, 01:29:55 PM »
I'm not sure if you're referring to the switch assembly or the starter button.
Regarding the starter button, you can buy new ones from:
Honda:  p/n 35317-001-310, if you lost your spring, I don't have that part number.
and
PartsNmore:
https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=electrical
scroll down 'til you get to the starter button.  It comes with the spring.
HTH
« Last Edit: September 06, 2010, 10:15:47 PM by rangelov »
http://forums.sohc4.net/index.php?topic=76835
CB750K4, Boss maroon metallic, 836cc, RC Engrg 4 into 1, Forks by Frank, air assisted front forks,  JC Whitney 16" rear.
Online Jerry Rxman Griffin aka MuthaF'er
« Reply #7 on: September 06, 2010, 01:48:23 PM »
Doesn't work on our bikes
Offline Mr. Mac
« Reply #8 on: September 06, 2010, 08:02:32 PM »
Does anyone make a real replacement?
Offline BeSeeingYou
« Reply #9 on: September 06, 2010, 08:30:52 PM »
Refer back to my earlier post.  It is an exact replacement for the right hand control with the exception of the color of the kill switch button. I just swapped the red button off the old one.
« Last Edit: September 06, 2010, 08:33:27 PM by srust58 »
Offline rangelov
« Reply #10 on: September 06, 2010, 10:22:41 PM »
Would you educate me on why it won't work?
I"m not familiar withe Fs.  But isn't the failure usually due the button disintegrating or the wire breaking near the solder joint or the solder joint itself near where the button contacts.  I can't belive that Honda would completely redesign a simple push contact switch, but, hey, what do I know?  Is the button the wrong size or shape?
I have CB750K4 and my button disintegrated.  Now I need a button and spring.
« Reply #11 on: September 06, 2010, 10:25:52 PM »
The later bikes have a more complicated button where the power to the headlight is disconnected before the power is transfered to the solenoid wire
Early ones one wire and button grounds the wire to the bars
Later ones three wires and button sends power to the solenoid
« Reply #12 on: September 06, 2010, 11:00:34 PM »
The 75/76 F switch has a button that is enclosed in a little plastic box that usually breaks, it's not the button that is the problem.
Offline rangelov
« Reply #13 on: September 13, 2010, 09:09:48 AM »
Thanks for the info.  Now I know a very little bit more.  I didn't realize there was that much difference.
« Reply #14 on: September 13, 2010, 09:55:00 AM »
Yeah, one of those "improvements" no doubt  ::)
Offline rangelov
« Reply #15 on: September 13, 2010, 11:32:50 AM »
I guess it could be called an improvement.  I had a 1976 Kawasaki KZ900.  The headlight stayed on all the time.  If the battery was low, it couldn't start because a lot of the electrical power went to the lighting.
