Author Topic: How do I learn about electrics?  (Read 4944 times)
Offline KB02
« on: February 24, 2006, 06:18:55 AM »
Lets fce it, as inteleigent as I like to think that I am I'm just a dummy when it comes to electronics.
I just recently got the latest DENNIS KIRK catalog and as I was flipping though it I cam across a DYNA ingintion for the SOHC. My initial question is "Can I use my stock coils with this ignition?" I performed a seach and found that I should be able to, but won't see as big of a benifit as I would if I were to buy lower Ohm coils (According to one post - "If my eletrical system can handle them"). Why? Why not?
I guess my basic problem is that I don't know the difference from Volts to amps, Ohms to resistance or ground to hot (okay, I DO[/i][/u] know that one). Does any one have a good place to go (website) or a good book to read that I may learn a little bit more about eletronics?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Gordon
  • 750K1, 550K2
Re: How do I learn about electrics?
« Reply #1 on: February 24, 2006, 06:31:16 AM »
Uh Oh!!  ;D ;D
Vatch
« Reply #2 on: February 24, 2006, 06:31:55 AM »
You might want to start with some basic electronics theory.  There are a lot of books out there that would do, anything like "Teach yourself electricity and electronics."  There's probably an "Electronics for dummies" book out there, or something like it.  From there you can get into more specialty material like electronics for bikes/cars.
Anyway, I learned most of what I know from two books and then trial and error.  A little theory goes a long way. ;)
« Reply #3 on: February 24, 2006, 10:10:41 AM »
You could try this one.
http://www.circuit-magic.com/laws.htm
72cafe
« Reply #4 on: February 24, 2006, 10:43:17 AM »
Nikoli Tesla created Alternating Current.  ::)
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: February 24, 2006, 10:44:20 AM »
I thought it was Al Gore.  ;D
« Reply #6 on: February 24, 2006, 11:36:22 AM »
Nikola Tesla
The Serbian-American inventor, electrical engineer, and scientist
Born on July 9/10, 1856 in Smiljan, Lika (Austria-Hungary)
Died on January 7, 1943 in New York City, New York (USA)
Inventions: a telephone repeater, rotating magnetic field principle, polyphase alternating-current system, induction motor, alternating-current power transmission, Tesla coil transformer, wireless communication, radio, fluorescent lights, and more than 700 other patents.
Online dusterdude
« Reply #7 on: February 24, 2006, 11:38:11 AM »
no bob,he invented the internet.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cb(r)
« Reply #8 on: February 24, 2006, 12:49:13 PM »
Nikola Tesla
probably one of his biggest accomplishments.   www.neuronet.pitt.edu/~bogdan/tesla/niagara.htm
dont forget the 80's rock band "Tesla".  Awesome!
sorry other than that I can not help with this topic.
by the way thanks again TWOTIRED for the website.  another good and bookmarked site.
72cafe
« Reply #9 on: February 24, 2006, 01:41:42 PM »
Uh Oh!!  ;D ;D
Boy!! Gordon called it on this one. Didn't expect it to go this way, eh?
OK. to help a little with this question. Ohms are resistance. Ohms are the unit of measurement used for resistance.  Therefore, if the coils have less Impedence (resistance, ohms) more current will pass through the coils-making a bigger spark. I think the idea is that the Dyna S kicks out a bit more juice, so the coils need to be a little less restrictive or they will get too hot.
The formula is
I=current, V=voltage, R=Ohms
I=V/R
So if you have these values, you can figure it out-I think the stock Toyo Denso's are 6 Ohms. Your alternator kicks out 12 Volts.
I=12/6
I (current)=2 Amps
Dyna coils are 3 Ohms
I=12/3
I=4 Amps
http://www.howstuffworks.com/
http://www.ndt-ed.org/EducationResources/CommunityCollege/EddyCurrents/Physics/currentflow.htm
It's been a while since basic electrical theory for me. I suck at memorizing stuff that I don't use on a daily basis. This is off the top of my head as far as units go.
Offline oldbiker
  • I HATE RAIN
« Reply #10 on: February 25, 2006, 12:41:55 AM »
KB02, a simple analogy helps. Think of water or hydraulic systems, I'm sure you understand water pressure and water flow.  Volts are the equvalent of pressure and Amps are the equivalent of flow. So if the battery is discharged and the voltage is low then you get less amps ie. less current flow.
Now you know the difference between Volts and Amps.
Offline KB02
« Reply #11 on: February 25, 2006, 05:18:16 AM »
Thanks, guys! Eletrics has always been one of my down falls when it comes to working on anything mechanical.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline jdpas29
  • my bike is 100% sandcast!!
    • My band = white bread
« Reply #12 on: February 25, 2006, 05:56:13 AM »
the best way to learn is on a vehicle you don't care too much about with a bucket load of extra fuses.  just trial and error stuff and learn what the ground color is first!!!  then go from there.  most of the time it's not as complicated as it looks.
like on a lot of these CBs, almost all of your grounds up front are green.  then the hot wire with be the variant and depending on its color, that's what part on the bike it will get power to.  a clymer manual has decent diagrams in the back that will help you along.
cars are gay.
Vatch
« Reply #13 on: February 25, 2006, 06:51:13 PM »
Just remember, smoke makes electronics work.  When the smoke comes out, you've broken it.  ;D
fhoffman
« Reply #14 on: February 25, 2006, 07:24:04 PM »
Haynes has a good manual called "Electrical Techbook" by Tony Tranter(3rd Ed), which I have found very helpful.  While you're purchasing that one, get the "Fuel Systems Techbook" by John Robinson. They are available though Whitehorse Press online.
They explain the concepts clearly and professionally, without talking to you like the "________ for Idiots" books do.  I use them as references, and there has only been one case when the answer I was looking for was not there... and that was the Starter Safety Box on my 1976 CB550... which is a strange and unnecessary piece of electronics, as demonstrated by it's removal for the 1977 model year.
Frank in Cleveland
carsholduptraffic
« Reply #15 on: February 28, 2006, 01:17:58 AM »
i like to get drunk before doing any electrical work to the beast.
i do auto wiring all day, so getting drunk makes it fun for me. i don't recommend this approach for newbies. you will set fire to something.
the only way to fix a 30yr old wirimg harness is to replace it.
cb750's dont draw a lot of juice (amps) so 3mm wire is fine.
sourcing the multiple entry bullet connectors is hard.
solder is good, but not on its own. that is why crimp connections rule the world.
the cb750k is simple from an electrical view. the diagram is complicated.
pay attention to earths(grounds, ve-. etc) and maintain them. lanolin (wool grease) works a treat.
the cb750 (k2) alternator is weak and my beast seems to smile more after a spell on the charger. i do run a small battery though. a topic of more research.
but if you persist with fixing up an old harness- get some flux amd a good so;dering iron, and find out why running a new wire is so much better...........
it is just wires after all..........
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline n9viw
  • Floyd, '76 CB550k
« Reply #17 on: February 28, 2006, 11:06:10 AM »
3mm wire? That's 9AWG! Stock wires this thing had was only 18AWG, except for the battery cables (Batt- to frame, Batt+ to solenoid, solenoid to starter) which were 6AWG.
The two biggest drains on the system are the coils and the headlight. Headlight is 3.5-5A (40-60W/12v), coils are 2.4A for stock and 4A for 3-ohm aftermarkets. Everything else, such as the turn signals ((27W/12)x2=4.5A momentary) and brake light (27W/12=2.25 temporary) are negligible. For all of this, 18AWG/600v is more than sufficient, providing 16A for total chassis wiring current and 2.3 for power transmission, which is based on a very conservative average.
Nick
'76 Honda CB550k
'73 Honda CB750k
Offline KB02
« Reply #18 on: February 28, 2006, 11:17:28 AM »
http://oldmanhonda.com/MC/WiringDiagrams/MCwiring.php
That sight brings up another question, though. I have a 1976 F (1?). That sight does not list a wiring diagram for my bike. Should I use the "K" diagram for the same year instead?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
