Author Topic: New Problem with 1972 CB750  (Read 1589 times)
Offline Arrico Wanders
« on: August 25, 2010, 11:47:08 AM »
I am a beginner at this.  I bought a 1972 CB750 about a month ago, I've been learning about simple maintenance and repair.  The members here have been very helpful on several issues I've run into.  Last week, I removed the front tire, replaced it, and rebuilt the front brake.  Meanwhile, I cleaned everything in the front end.  That went well.  I followed the instructions regarding rebuilding the brakes in the FAQ.  So far so good.  Finished that Saturday night.  Rode it Sunday for several short trips, none more than about 10 miles.  It ran great, brakes worked well, no problems, good power.
This morning, I noticed that there was a puddle of oil under the bike.  Importantly, as background info, I have drained and replaced the oil and oil filter, replaced the fuel and included a fuel treatment, replaced the spark plugs, replaced the battery.
Today, I decided to take it for a spin, and it ran really poorly.   Previously, it was requiring no choke, starting on first try, idling very smoothly without problems.  Today, it would not idle without using the choke at first (wide open, then gradually closing it).  I could barely keep it started!  I was able to get moving, and I had no power!  It was running, but just barely.  The exhaust note was different than normal, it sounded like a deeper rumble than normal.  The bike would stall out any time I slowed down, or let off of the throttle.  I went around the block, then limped it back home.  Upon arriving home, I looked under the bike.  There are definitely signs of a leak around the bolt at the base of the oil filter assembly.  I could be mistaken, but I don't think I messed with this bolt previously.  Can't say for sure, so I included a picture of it.
I did a search on here, and found a mention of testing to see if the cylinders are firing by licking your finger, and touching each pipe as it exits the engine.  I did this, and the pipes coming from cylinders #1 and #2 are not warm.  #3 and #4 are hot.
Hopefully unrelated, but might be important:  when I replaced the spark plugs, the spark plug wires for #2 and #3 were old and sort of frayed.  I trimmed the ends of these wires, screwed in the spark plug caps and reinstalled.  Didn't seem like a big deal, and it still seems to feel tight and sturdy.
Any advice would be greatly appreciated.
AW
Re: New Problem with 1972 CB750
« Reply #1 on: August 25, 2010, 11:47:48 AM »
Forgot the picture...
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: August 25, 2010, 11:58:55 AM »
Where was this puddle at in reference to your bike? Looks like you have an oil leak somewhere, if it is not too significant (a quart every couple of weeks that is not too bad).
Your gas treatment could have displaced some dirt or particles into your slow jet circuit and gummed up the works, looks like you will get to learn about your carburetors real soon. This wil probably involve a teardown and cleaning of the carbs.
You will also want to check your spark from the points or CDI to the plugs, testing to see if you get a decent, reliable spark.
« Reply #3 on: August 25, 2010, 12:00:53 PM »
So, you think this is 2 separate issues?
« Reply #4 on: August 25, 2010, 12:28:35 PM »
Check for fuel delivery to carbs and spark, could be a combination, might not.
You don't know until you check them off the list, I would recommend performing a complete tune up on this bike in cluding looking at the ignition and then attacking the carbs LAST.
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #5 on: August 25, 2010, 01:15:19 PM »
Do a compression check if you have a compression tester.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
« Reply #6 on: August 25, 2010, 01:45:46 PM »
OK, potentially stupid sounding question:
What's a tune up?
« Reply #7 on: August 25, 2010, 01:52:07 PM »
got a clymer manual and or downloaded the shop manual?
honda recommends certain maintenance(tune-ups) be done at specific mileage intervals.
the 3000mi maintenance procedures will cover all areas of a well tuned Four...
start there.
Offline Johnie
« Reply #8 on: August 25, 2010, 01:55:59 PM »
Regarding that oil leak by the filter housing. Did you use a Honda filter or aftermarket? And did you replace the small O ring behind the oil filter bolt?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #9 on: August 25, 2010, 02:02:31 PM »
I bought the filter at the Honda dealer.  I think it was Honda equipment.  I'm not positive about that specific O ring, but I'm thinking I need to check.
Isn't some of the stuff I'be already done part of a "tune-up"?
« Reply #10 on: August 25, 2010, 04:10:03 PM »
Weird.
I just went out and started it again, and it was back to normal power.  Sounded better, all four pipes getting hot now.
Still leaking some, but something's better.  I didn't do anything.  Wonder what happened there?
AW
Offline Johnie
« Reply #11 on: August 25, 2010, 06:08:41 PM »
Just to clarify, that O ring actually goes on the oil filter bolt in a groove. If it is missing or torn you could have a leak like yours.
Oshkosh, WI  USA
« Reply #12 on: August 25, 2010, 07:47:13 PM »
Thanks, will definitely take a look at that.
What do you guys think happened?   It seems to be back to normal, but it's sort of disturbing.  What if I get out somewhere on the bike and this happens again?!?!?   I'm definitely not confident about the reliability right now.  Guess I need to go through some tune up steps before I get too far away from home...
Offline 77cafe750
« Reply #13 on: August 25, 2010, 08:16:25 PM »
sounds like maybe something got dislodeged by that fuel cleaner and maybe cloged a jet then fell back to the bottom of the carb bowl i would at least pull the bowls and check
peace crash
live like an outlaw and love like an angel
crash
blacked out gauges rock
http://forums.sohc4.net/index.php?topic=67710.0
Offline Roach Carver
« Reply #14 on: August 26, 2010, 08:35:47 AM »
As everyone else said, time to go thru the carbs. You need to know how they work anyway so you can fix them if they do strand you somewhere. Not that difficult of a job and when they are really clean it will amaze you how smooth it will run.
