Hi guys
1974 cb740k
I recently completed an engine(valves, skimmed, rings, pistons,gaskets).I also installed the original pipes and airbox with K&N Filter.
Carb jets were checked 110 and 40's. (Standard i presume as they were the same as other Carbs i got).
She goes fine up until about 4000rpm, then she struggles to go higher, then she seems to wanna go alot better around 6000 (don't wanna take it higher, running in) , is this the "Flat" spot?
I though it was points, so i replaced em. Same as before.
Cut the plug cables to new wire.
The carbs i took out of a running bike (with pods however), i have done the fuel/Air to one and a half turns out.
I also tested her by dropping the airbox bottom and it didn't seem to make a difference.
She idles a bit rough but it's all good until 4000(smooth), after she just seems to struggle.
Any futher ideas...
Thanks
Thor
