Author Topic: Undercut transmission, or rev limiter?  (Read 15847 times)
Re: Undercut transmission, or rev limiter?
« Reply #50 on: September 01, 2010, 05:06:43 PM »
Nah mate, it's the "piston to cylinder wall" clearance that'll (possibly) be tight, due to the ceramic coating adding a couple of thou to the OD of the pistons. i don't know what the clearances are now, but I'm guessing .001 - .0015? Cheers, Terry. ;D
After i posted i thought you would say that, i was only planning on coating the piston tops... ;)
« Reply #51 on: September 01, 2010, 05:33:41 PM »
OK mate, that sounds like a good idea. Cheers, Terry. ;D
« Reply #52 on: September 01, 2010, 06:03:12 PM »
I just got the quote back Mick, $225.00 plus GST to cryogenically treat the whole gearbox, sweet! I'll drop it off tomorrow! ;D
Wouldn't it be best to do the undercut before the cryo treatment?
« Reply #53 on: September 01, 2010, 06:07:43 PM »
Apparently it makes no difference, as the cryo treatment is not a "coating" or "surface hardening", but changes the whole molecular structure of the steel, so you won't cut/grind through a thin layer of hardening. If the dogs are in good condition though, I'm wondering if they'll need to be undercut after cryo treatment? What are your thoughts mate? Cheers, Terry. ;D
« Reply #54 on: September 01, 2010, 06:13:33 PM »
With a big motor and used gears, I think I would go ahead and undercut, just to be safe. My concern about doing the undercut first would be heat generated by grinding might(?) change the molecular structure back.
« Reply #55 on: September 01, 2010, 06:17:55 PM »
Interesting, i would probably cut first. I wonder if this Cryo treatment can be used on bearings and chains...?
« Reply #56 on: September 01, 2010, 06:19:25 PM »
OK mate, I'll think seriously about it, they do say in their blurb that components can be machined afterwards with no ill effect, but I did wonder about it at the time. Cheers, Terry. ;D
I think Ron (MCRider) did get his done Mick, but I'm not sure. Cheers, Terry. ;D
« Reply #57 on: September 02, 2010, 06:47:13 PM »
Well Paul in Sydney (K2 836) put me onto an engineer who'll undercut my gears for only $185.00! Woohoo! I rang him a moment ago, he's an older guy and seems to know what he's talking about, so I'll send them off on Monday, thanks Paul! ;D
Offline Bill/BentON Racing
    • BentON Racing
« Reply #58 on: September 02, 2010, 09:04:34 PM »
I believe MCRider did his.I too would undercut and do it first.Bill
BentON Racing Website
BentON Racing Facebook
« Reply #59 on: September 03, 2010, 02:23:39 AM »
Yep, that's the plan Bill, get 'em undercut, then Cryo treated. Has anyone got a pic of a CB750 transmission with the gears numbered? Scottly said not to get first gear undercut, so I'll need to pull it out before I send my gears off. Cheers, Terry. ;D
Offline mick7504
« Reply #60 on: September 03, 2010, 05:56:47 AM »
Terry
How are you mate
I haven't got ém numbered but they're all laying together on their shafts.
This is the job that Big Jay did for me.
Still smilin'  ;D
If I was you
I'd be worried about me.
« Reply #61 on: September 03, 2010, 10:23:09 AM »
It wasn't me... ;)
Don't bother undercutting the first gear set either Terry, it just makes it tougher to find neutral.
« Reply #62 on: September 03, 2010, 10:32:44 AM »
I'll answer multiple questions here. My Cryo texch said they do everything, chains, (even ORing) gears, shafts, pistons, valves, cams, etc, engine blocks (says the drag guys get 3X more runs from a cryo block than non cryo, before they have to re-linbore it).  Sprockets, rotors, cam blocks, I did it all. They prefer machining be done first, then Cryo.
Only caveat on the chains was they want to do new ones. Used ones may have damage and so I had my used ones magnfluxed, and then they were OK to cryo. On the ORing chain, they say just be sure they know, key is simply don't move it till the cryo is done or the oring shatters. duh.
Caveat on bearings is the grease and rubber seals. If internal tranny type, then no problem to cryo.
On the undercutting,  APE charge for 4 cuts. So I asked Jay to cut 1-2, 2-3, 3,4 and 3-2. I figured why 4 to 5? Never a problem there. I have had the 3 to2 jump out on me so I picked that one. Heck they will do all 8, anything for a price, but not for me.
« Last Edit: September 03, 2010, 10:36:49 AM by MCRider »
« Reply #63 on: September 03, 2010, 03:18:53 PM »
It wasn't me... ;)
Oops, sorry Scottly, you're right mate, it was Brent Waller. Cheers, Terry. ;D
« Reply #64 on: September 03, 2010, 03:21:43 PM »
Thanks Ron, and I've got new primary and cam chains here, so I'll get them cryo treated while I'm at it. Cheers, Terry. ;D
Offline 72hondacb750
« Reply #65 on: October 21, 2010, 12:53:14 AM »
Iwould kill for a good how-to // diy on undercutting .. I get some missed shifts and pops on mine but don't gave the means right now to dump 300 + shipping + downtime into my bike .... If I did myself I'd just get another set of trans gears.
72 CB750 cafe project
Offline mick7504
« Reply #66 on: October 21, 2010, 04:49:20 AM »
Mate
It is serious dough for a serious job.
What Big Jay can do for you will kick butt and plenty of it.  ;D
If I was you
« Reply #67 on: October 21, 2010, 04:57:04 AM »
I got mine back from Sydney Mick, brilliant job, and only 185 bucks, woohoo! ;D
Offline mick7504
« Reply #68 on: October 21, 2010, 05:02:11 AM »
Did you end up getting the Cryo done on it as well mate?
If I was you
« Reply #69 on: October 21, 2010, 09:23:02 AM »
What if someone made a guide and a block to check your work with.. .. Anyone here have the means ? I'll prepay for one.
« Reply #70 on: October 21, 2010, 12:55:32 PM »
I will, it's just that having sold 4 bikes to mostly interstate buyers I've been running around getting freight quotes and packing up spares Mick, but once I get some time I'll get it all across for Cryo treatment too. Like you said awhile ago, it's only money!  ;D
Offline kos
    • m3racing.com
« Reply #71 on: October 21, 2010, 01:54:34 PM »
For a racing machine we undercut gears, as it makes for a very positive shifting machine, but remember, you are removing the heat treat and or surface hardening and the dogs will wear at a much higher rate than OEM non modified gears. Unless of course you go back and re-treat dogs. We used to touch up (regrind) dogs on our M3 racing machines every winter when we had engines down for inspection and that seemed to work well, but if we skipped this procedure, it would come back to haunt us with missed shifts and constant slipping out of gear while in the hunt! And this made our rider, very unhappy!
KOS
KOS
220...221, whatever it takes.
« Reply #72 on: October 21, 2010, 03:51:04 PM »
KOS
Thanks for that mate, re: the situation of cutting thru the surface hardening, have you tried the Cryo treatment? From what I can gather, it hardens the material right thru to the core, so I assume that this would negate the need to regrind the dogs on a regular basis? Cheers, Terry. ;D
« Reply #73 on: October 21, 2010, 04:39:53 PM »
Terry: Not actually hardness in terms of "Rockwell" but stabilization and other characteristics that might provide the same results.
http://www.cryogenicsofindiana.com/
Would be good to know. I hadn't thought of what KOS brought up, but I have had my gears Cryod after the undercutting. I doubt that I'd put my tranny thru in a lifetime what KOS sees in a season or less, so mine won't be a good test..
« Last Edit: October 21, 2010, 04:46:33 PM by MCRider »
« Reply #74 on: October 21, 2010, 09:41:50 PM »
Use a transfer dye on the edge of the hole the dogs engage, fit the gears together and note where the dye shows on the dogs; the contact should be closest to the gear. Using a Dremel with angled stones, carefully undercut the dogs, making sure to remove the same amount from each dog, so the load is evenly distributed. The dye will guide you. Work slowly. Only a small amount of under-cut is necessary: too much will make shifting difficult without "floating" the throttle.
By the way, this process is only for those with more time than money. ;)
Mate
