Author Topic: clunk in forks  (Read 1053 times)
Offline ben.cb500
clunk in forks
« on: August 29, 2010, 08:08:08 AM »
I have a clunk noise on the rebound in my front forks. I have ruled out the front caliper assembly as referenced by other posts.
Its a CB500 71. It sat forever, I drained the forks; unbolted the top caps and pulled the assembly out enough to refill them with ATF measured as per manual. Then pushed down on springs and retightened fork bolts.
The performance has improved, but I have noticed this noise since.
Any ideas?
Are there any good write ups on a complete teardown, would make a good winter project.
thx
Offline voxonda
Re: clunk in forks
« Reply #1 on: August 29, 2010, 08:11:36 AM »
Did you put in the small rebound springs?
Offline ben.cb500
Re: clunk in forks
« Reply #2 on: August 29, 2010, 08:14:56 AM »
I did not dissassemble the forks, only pulled the springs and rod up enough to refill them. I only saw 1 contiguous spring....can you enlighten me on the small rebound spring? perhaps I have dislodged it in reassemby (which amounted to applying pressure to the top pushing all back in and tightening).
Thanks
Re: clunk in forks
« Reply #3 on: August 29, 2010, 08:59:13 AM »
3 things come to mind:
1. Put the bike on the centerstand, then rock it back so the forks are off the ground, then forward to compress them, several times. If there is rust and crud in a few of the damping holes, this will help dislodge it and flush it out so the lower end of the damper can fill up again.
2. If the oil amount was less than 7 ounces, add some more oil. Many manuals I have seen lately have the wrong oil amount. Add at least 1 ounce of oil to what you have: for example, after a full rebuild where the parts are dry, it takes about 1-2 ounces extra oil to fill things up properly again. Draining the forks via the little drain bolts doesn't really empty everything by itself: you have to remove one fork cap at a time, then pump the open one (and make a mess...), then repeat on the other side, to get it all. Then you have to refill the inner dampers, as described in #1 above, or they will 'clunk' on small bumps until they finally refill by themselves.
3. Make sure the steering head is tight: if the balls and races are still there (i.e., no one replaced them with tapered bearings instead) they may be worn and loose. You might just have happened to notice it now after other work...  ;)
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
Re: clunk in forks
« Reply #4 on: August 29, 2010, 09:41:29 AM »
Check your brake bracket galiper...
Offline Alan F.
Re: clunk in forks
« Reply #5 on: August 29, 2010, 06:56:52 PM »
Winter project?  3 hours end to end including beer runs.
