Hey, I have a related question here..
So, the general concensus here is that you can shift without a clutch- some guys say it's not hard on the trans, other disagree, but obviously it is possible to shift this way.
So, what if your clutch cable breaks away from home, and you don't have a spare? You can upshift and downshift, but how would you start out? If you're at a light, can you put the bike in nuetral, and when the light turns green, run with it, then slam it into first when you get back on the seat? Also, how would you stop? Shift it out of gear while moving, and into neutral?
Jason
