Many thanks, Andy.
The pictures showed me that I never saw the hole that the right hand line goes thru. Now I understand the fuel line routing.
Before Andy's post, I was playing with it again today.
I found that spraying WD-40 into the fuel line end allows it to slip easily onto to the carb tee, while holding the tee steady with a 8mm open end wrench. I noticed after a few days that it will not come off easily.
Getting any line off the petcock is always a pain. Andy, I see that your line didn't come off the petcock nipple. Sometimes it is better to cut it off. Did it break off or slip out of the petcock? If it slipped out, You should be able to Loctitie it in place. If it broke off, new petcock (Honda or Pingel?) or make a new nipple to replace old one after drilling out the remants?
I ran the left hand fuel line from the tee between carbs #1 & #2 back around carbs #2 & #3 above the air box to carb rubbers. I then fed it thru the small round hole in the carb plate holder between carbs #3 & #4.
I ran the right fuel line from the tee between carbs #3 & #4 forward and thru the hole made by the carb mount plate and carb #4 choke lever to the right of the small round hole that the left line went thru. This is where Andy's photo shows this is wrong and needs to go thru the plate using the lower round hole.
I wish my petcock was on the left side, just like my other motorcycles.
Tygon is fine. But I heard it gets very hard after being in service for a while. I had some sort of clear line on my CB125. It worked well. After many years, it also hardened up. I called a manufacturer a few months ago. They had a great product (NexGen). But the product manager said any type of plastic used for a fuel line will have problems.
I have 4 feet of Goodyear 3/16 fuel line, which I paid less than 3 dollars. I also have 5.5 mm rubber fuel hose that I bought from a local Suzuki dealer. Both lines fit the fittings well and have a relatively tight bend radius.
