Yea, I'm sorry...maybe we got of on the wrong foot.
I am building a motor with an rc 315 cam and 12-1 compression, 836cc.
The reason I asked is because I know that the stock rod bolts are the weak link, I have found some other post/ and suggestions from members that suggest that I could use various aftermarket bolts and have the rods modified to accept them, I was factoring in the price of the bolts and machine work verses just buying these brand new also. I am assuming(there is that word again) that they have better than stock bolts, ready to go. I'n not saying it won't seen an occasional high rpm run through the gears, it's just not what I'm building it for.
The stock rods were heavily neglected, surface rust and the small ends are black from cooking under the dome, I think from very poor jetting, this has me a little concerned about the metalurgy of them.
On the build list, which is what I trying to balance
gaskets, seals, main and rod bearings, all tranny bearings, clutch plate set from ape, crank balance and lighten from ape, case and head studs, timing chain and tensioner/slider parts, stainless valves, springs, ti retainers, primary chains/tensioner, electronic ignition conversion, new modern rings for the 836 pistons. I am a die hard believer in blueprint/balance type details.
Thats not even counting the chassis, which is a bare frame as almost everything on it was just too rusted to reuse, thats a whole new money pit. It is a hard tail chopper, not really suitable for racing, but I would like it to be very quick should I have occasion to need it to be. 98% of the time it will just reliable cruise around town and hopefully be a blast to ride, with a nice tough sounding engine.
