Author Topic: Bogging Down When the Engine is Hot  (Read 1977 times)
gaillarry
« on: April 27, 2005, 06:02:42 PM »
I just replaced the head gasket on my 78 CB750K and after about 50 miles, the gasket is leaking again!  I'll have to re-torque the headbolts.
Since I replaced the gasket the bike will bog down when the engine gets hot.  Otherwise it runs great.  A biker behind me says he can smell gas when the bike is hot.  I didn't touch the carbs so I'm baffled!   Any suggestions.
Ben
Re: Bogging Down When the Engine is Hot
« Reply #1 on: April 27, 2005, 06:27:22 PM »
Hiya,
Your bike is definitely running rich (as I'm sure you have worked out!). Try removing the air filter and taking it for a quick spin. The filter may be blocked.
Cheers.
gaillarry
« Reply #2 on: April 27, 2005, 06:53:46 PM »
The air screws are set at 1 1/4 turns out, obviously I'll have to open them up more.
