Author Topic: Another "F'ed" CB750F  (Read 2895 times)
Offline JohnPayne
« on: September 07, 2010, 05:51:33 PM »
This is my first CB, and my first project bike. I am loving it so far, the more I tear into it, the more beautiful it becomes to me. It's an F3, with 28k miles on it. The #4 cylinder wasn't firing, and when I when to look at the tappet adjust to see if that was this issues...there was no tappet adjuster, it had come off and was floating around in the cylinder head. So, I began to strip it down and pull it apart over this long Labor day weekend. The motor is out (laid the bike on it's side, it was pretty easy actually with a couple of helpers) and I just took the head off. I will be sending to Mike Rieck with a head rebuild kit from Cycle Exchange. If there is any pointers or tips you guys have for me in the process please feel free.
This is what it looked like when I first got it and cleaned it up (Not running):
The phantom tappet adjuster:
And it's spark plug:
The tear down:
#1
#2
#3
And #4 The one that was missing the tappet adjuster, When I took off the head the valve spring was just floating freely around as well.
The worst looking piston:
The command center:
1978 CB750F
1991 Harley Sportster XLH 883
Offline JohnPayne
Re: Another "F'ed" CB750F
« Reply #1 on: September 07, 2010, 05:55:20 PM »
I wasn't planning on doing past the head engine tear down wise. Whats your opinion on this? Like an idiot I didn't do a compression test before hand to see if a really needed to. Any recommendations on cleaning the cyliners/pistons?
1978 CB750F
Offline gearhead ed
« Reply #2 on: September 07, 2010, 07:13:40 PM »
Good luck with the rebuild. I have a 1978 f3 and I just replaced my cam tower pucks. I cut my frame so that I could leave the motor in place. I have used a soft wire wheel in the past on the piston tops and it worked for me. Check out the 750f thread for some builds.
1978 750f    1964 Chrysler 300
« Reply #3 on: September 07, 2010, 07:39:34 PM »
CycleX do a "head rebuild kit" for a F2/F3?
Offline JohnPayne
« Reply #4 on: September 07, 2010, 08:32:48 PM »
1978 CB750F
« Reply #5 on: September 07, 2010, 09:55:19 PM »
If you plan on doing any miles on that bike you may want some decent tires. Those things will track like a #$%*, i would only use them on a slow round town special, definitely not a highway or touring bike...
Offline JohnPayne
« Reply #6 on: September 07, 2010, 10:16:43 PM »
Hah, yeah. They look terrible as well. Unfortunately they came brand new with the bike. Maybe I will toss them on craigslist or something.
1978 CB750F
« Reply #7 on: September 07, 2010, 10:18:37 PM »
They do look cool and would suit a nice little rigid for bar hopping,  but your F bike will like you more with some decent tires.... ;)
Offline JohnPayne
« Reply #8 on: September 07, 2010, 10:22:43 PM »
So, if I have the head off, do you guys think should I just keep going and do piston rings? Anything else as well?
1978 CB750F
« Reply #9 on: September 07, 2010, 10:45:37 PM »
It's a crap shoot at this point. Can't hurt but may not be needed but not sure if you can get the rings anymore. On the shelf next to the hens teeth. Much discussion about that but I haven't heard anyone that has found off the shelf F2/F3 rings. You may have to ship off the pistons to Total Seal for cutting and fitting.  If you install a frame kit you won't need to tear your whole bike apart to ring it later (if needed). And the law of averages states that if you do something proactive like that you won't need it anyway.
Anything else?? How much cash or credit card do you have left? I will have well over $5000 in my engine. I'd say maybe $10,000 is about the ceiling but $7000 will get you a damn fine engine like mine. Seriously! Doing the head, etc and a 836 kit is probably good enough for the first time. Next step is bigger pistons, rods, and carbs. Save that for the next time you need to get into it.
Offline JohnPayne
« Reply #10 on: September 07, 2010, 11:00:05 PM »
Hah, I would love to do 836cc. Right now is not the time financially, I am only working part time because I am in school. I am probably working with $1500-2k budget. I want to do, new front and rear suspension $400, Yoshi replica exhaust $300, powdercoat wheels and frame (not sure about the price of that yet), the head rebuild will be about $700 after Mike R is done porting it and putting all together. I guess I will see where it takes me and what this addiction makes me buy (probably more than i need).
1978 CB750F
Offline tweakin
  • tear down
« Reply #11 on: September 08, 2010, 05:39:54 AM »
I have a set of New old stock F2 piston rings, never been used, in original packaging.
Shoot me a PM if you are interested.
Offline MasterChief750
  • Detonation
« Reply #12 on: September 08, 2010, 06:51:33 AM »
chem dip will take the carbon right off the pistons. i think the rings are still available from honda.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline JohnPayne
« Reply #13 on: September 08, 2010, 03:08:32 PM »
Whats your method, put chem dip into the cylinders? Or remove them and dip?
1978 CB750F
  • Detonation
« Reply #14 on: September 08, 2010, 06:27:45 PM »
remove them then dip is what i did. works well on the head combustion chambers as well let them sit for a day prolly each and it will wipe off.
I AM THE STIG
Sam is THE STIG
Offline HedNut
  • Underwater Basket Weaving
« Reply #15 on: September 09, 2010, 04:33:36 AM »
I love F'n Builds!!  Cool stuff....Looks like you got a great bike there!!
With my K8 I'm up to somewhere between $1300-$1600... including the cost of my bike ($300) So far... you can get a lot done with that if you're "thrifty".... I didn't get any head work, powdercoating, exhaust or new suspension...yet! ahah  But your bike seems to be in a bit better shape to start off with!
Cheers! I will be watching this one!
