Moped riding in Brooklyn is a little sketchy. I try to stick to the slower streets...then haul ass down them
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
Pics are coming, but I've done a bit...
I researched and discovered that the Minarelli motor came in a few configurations (20MPH, 25-30MPH)... The Gloria is the 20MPH version with a highly restricted exhaust and a smaller carb (14.12 MM)... The General motor has the 25-30MPH engine, so the carb is bigger (14.9 MM)...not sure about the exhaust b/c mine doesn't have one!
So I pulled the carb on the Gloria and replaced it with a new Dellorto SHA 16.16MM. At first it wouldn't start so I checked the jet. The jetting was set at 82... I pulled that out and dropped in a 56 and vroom!!
To get her to idle with the 56 I had to screw the idle screw all the way in, but she idles perfectly now... also, she's noticeably faster!
Question: Can I drop to a smaller jet and get it to idle with the idle screw turned out more? Do I care? (remember it idles perfectly right now) Will I lose performance if I drop in the smaller jet?
The General: I've pulled the tank and filled it with vinegar, I'll let it soak a few days. There isn't much rust, but it isn't perfect either. Once I get it clean I'll flush it with 2 stroke oil to leave a protective layer inside until I gas her up.
I'm going to replace the petcock since they're only $15 and I can ensure proper flow. I'm also cleaning up the frame right now.
Cheers
