Author Topic: 1976 cb750A and 1973 cb750- interchangeable parts?  (Read 2707 times)
Offline Aatrain
« on: September 11, 2010, 01:46:15 PM »
I just got a 73 750 that I'm going to be rebuilding. I have a shot at a 76 750A for a donor bike for nearly nothing. Are there more differences than the transmissions? Would I get a lot of compatibility from frame and engine and carbs? Thanks for the help...
Aaron
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: 1976 cb750A and 1973 cb750- interchangeable parts?
« Reply #1 on: September 11, 2010, 02:14:11 PM »
Not very many things are the same between the A and the other 750s. The frame, seat, carbs, forks, wheels, transmission and bottom half of the engine are all different. The cylinders, pistons and head from a K are close enough to interchange. Hope this helps.
................Paul
« Reply #2 on: September 11, 2010, 02:25:13 PM »
The carbs are different,smaller,and the pistons have less compression along with the other differences. Look for another K.
« Reply #3 on: September 11, 2010, 03:59:18 PM »
Get the A, sell it here for a modest profit, or use it for trading material.
Offline Aatrain
« Reply #4 on: September 11, 2010, 04:58:45 PM »
Thanks for the input. I thought about going ahead and getting the A for another project or turning over- jury is still out. The 73 is going to be a heck of a project in itself. To crowd things a bit more, I have a 74 350 that I still haven't finished in the shop (which is too small to begin with!)
The main things I think the 73 is going to need replaced are the top end and pistons and the forks. Electrical. All that good stuff.
Thanks again for the input.
Aaron
