Its been a while so I figure a short intro would be good.
Bought this
Stripped it down to this and got the engine out to be cleaned and painted.
I took of the center stand assembly and dont plan on keeping it. I disassembled the rear and front tire and took out the forks. Basically got it down to the bare frame minus the steering assembly that I want to take off and repaint.
Here is a photo of my carbs when I first took them apart.
Then after I took them apart I cleaned them in this Yamaha carb cleaning solution that you mix two parts solution to one part h20
This was before I found out my neighbor had this chemical bath he uses to restore all his motorcycle parts et cetera, here is a photo of the bath
And of the carbs after the bath
Then I polished the float bowls with a Baldor 1/2 hp buffer grinder.
Put new carb kits in them from Z1 enterprises, and put on my velocity stacks from Steel Dragon Performance
But I broke this bolt in one of the carbs, I figure it isnt that bad as long as it stays right
? Probably not so I guess Im just naive.
So I took off the swingarm and disassembled it thinking I would send it off to Hondaman cos I read he does some nice rebuilds of these things, it was annoying getting those old steel bushings or sleeves out.
This is a picture of various parts I bought for this build.
I was going to put this yamaha r6 front end but All Balls told me their conversion kit is out of stock until June, so I am currently collecting parts to do that dual front brake caliper conversion for these 550s.
Pretty cool it came with dual front brake calipers and both clip ons.
Here is a Dresda swingarm I thought would fit, bought it off ebay, bought it before the seller could tell me the dimensions of this thing. This Dresda swingarm is for a 650, guess I was being naive again and was hoping it would fit.
Here is a foto of the swingarm not fitting
Its because it is not wide enough
But this 86 gsxr swingarm fits like a glove, except neither mounting bolt is compatible AND the dunlop swingarm is longer than the stock 550 swingarm, this needs to be cut down to match the same length.
And so while I am looking for parts for that dual disc conversion...I decided to take out the forks and I found little to no fork fluid in both with small trace amounts of h20.
This is what came out of BOTH forks
So I know that rust in the fork travel area is bad. Both forks looked like this, and only had rust where the headlight ears used to be.
What should I use to remove this rust? I could take it to my neighbors chemical bath and clean every part from the fork assembly or any other suggestions?
So this is where I am currently at right now. I still need to finish cleaning the engine, mount it to my engine stand and paint it. I will prolly polish some parts of the engine too.
I will most likely put up that Dresda swingarm up for sale later today or tomorrow. So best to wait for that post in the appropriate section.
