Author Topic: Any fixing brake piston  (Read 1220 times)
Offline jays75
« on: September 15, 2010, 04:41:22 AM »
Sup,
I have successfully broken down my bike and now it's time to replace stuff.  The stuff in question is my brake piston. I have a '75 550 and when I took apart my front brake, which was quite easy using the grease gun method, I noticed the piston had some pits in it right where it sits on the seal.  Question is do I try and clean that up or do I replace the whole thing?  If I replace it then where can I get a good piston from?
I could buy them all day off ebay and what-not but I figure those pistons would be pitted just like mine.  I dunno.  Maybe I need more faith in people.  Any help in this matter is a huge help.  Right now I'm at a stand still until I get this front brake back together.
Offline knowsnothing
Re: Any fixing brake piston
« Reply #1 on: September 15, 2010, 06:07:20 AM »
Hey Jay,
You will most likely need to replace that piston.  Luckily a member here (Kevin400F) makes phenolic replacements, which are lighter and just as good if not better than OEM.  I am pretty sure he makes one to fit your bike.  Go here for all the info >  http://forums.sohc4.net/index.php?topic=66881.msg736356#msg736356
« Last Edit: September 15, 2010, 06:09:23 AM by knowsnothing »
1978 CB750k Blue - for sale
Offline HondanutRider
« Reply #2 on: September 15, 2010, 06:10:24 AM »
Depends on how bad the pitting is.  (Maybe a picture would help...)  If its not too bad, they usually can be cleaned and polished, and with new pads and maybe a new seal, the pits won't cause a problem.  If you use new pads, then the seal will be positioned in a new spot, hopefully avoiding the pits.
Another route, probably better, is to get a new piston.  This is possible for some models (but not for my 81 DOHC CB750-K - as I found).  In fact, one of the members here builds phenolic pistons that don't rust or pit and the reference above is to him.
Online bryanj
« Reply #3 on: September 15, 2010, 09:20:21 AM »
Is your life worth more than the cost of a proper brake rebuild?
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: September 15, 2010, 09:23:38 AM »
Phenolic, no need to look elsewhere.
bollingball
« Reply #5 on: September 15, 2010, 09:25:35 AM »
DO NOT take a chance on brake parts !!! Being able to stop is way more important than being able to go fast.
Offline faux fiddy
  • bike in a box
« Reply #6 on: September 16, 2010, 06:32:41 AM »
Carcass bikes all seem to be missing the  handlebar controls, master cylinder first. AWhat does that tell you?
i'm looking for a 350f master cylinder. I think the 550 is the same.I will check back on this thread..
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline the architect
« Reply #7 on: September 16, 2010, 07:08:16 AM »
Another option, other than phenolic, is stainless steel.  I picked up a s.s. piston when I rebuilt my K5's caliper last year.  Should nver corrode or pit again.  And it's metal.  I like metal.
Rider no. 83 on the 2013 SOHC/4 Honda World Tour
Rider no. 228 on the 2012 SOHC/4 Honda World Tour
Rider no. 70 on the 2011 SOHC/4 Honda World Tour
my '75 CB750 cafe build photo documentary:  looking for the Lone Stars is like playing Where's Waldo -- enjoy.
http://www.flickr.com/photos/34828040@N05/sets/72157615892537535/
CB350 twin, rigid meat grinder:
http://www.flickr.com/photos/34828040@N05/sets/72157627005176764/
Blip Workshop
http://www.blipworkshop.com
http://www.facebook.com/blipworkshop
« Reply #8 on: September 16, 2010, 08:39:27 AM »
Stainless steel corrodes, ask the people that maintain the gateway arch.
Offline Kevin400F
« Reply #9 on: September 16, 2010, 12:23:06 PM »
I understand there are skeptics about the phenolics.   They work, I have one in my track bike (see pic below)  I'm not worried in the least bit about function, but please make a choice that you are most comfortable with.
Offline jays75
« Reply #10 on: September 17, 2010, 08:07:43 AM »
I think I'll go with the phenolic.  Sounds simple enough and simple is good.  Thanks again for all your replys to the topic.
J.
