Author Topic: electric experts: testing and trouble shooting  (Read 598 times)
Offline highrpms
« on: September 15, 2010, 06:43:32 PM »
the battery is fine and has been tested.
my bike dies after running it drains it. i tested the voltage while running and it was always 12.5 from idle (1000rpm) to 5000rpms... no increases and needle jumps...
does that tell me any thing in the chain of the charging system?
stator, regulator, rectifier???
what else need to be done? tested to identify the source of the issue.
i wd40'd up that stator cover in order to take that off to test that tomorrow.
ideas? or quick tests or items to check?
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
Re: electric experts: testing and trouble shooting
« Reply #1 on: September 15, 2010, 07:10:06 PM »
 ;) Check the Faq! 2nd one down!
http://forums.sohc4.net/index.php?topic=1012.0
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
