Author Topic: High Altitude + CB550 + Pods = Jet Size?  (Read 2023 times)
Offline theofam
  • I'm cold, give me a
  • Suffering from MDD - Mechanical Deficit Disorder
« on: February 08, 2010, 08:17:51 AM »
I'm about to embark upon my first carb rebuild for my CB550.  I plan on running pods and live in Denver (5000+ ft), so I'm looking for advice from any of you out there at a like altitude with a similar setup.  Any jetting experience you could share with me would be much appreciated!
Offline Triffecpa
Re: High Altitude + CB550 + Pods = Jet Size?
« Reply #1 on: February 08, 2010, 09:30:46 AM »
I run two CB550 trackbikes in ABQ (similar elevation).  I run basically an open 4-1 pipe with velocity stacks.  I use 105 main jets.  So I would probably look for 102.5's or maybe 100's if you are running pods and a baffle in your exhaust.
Tracy
« Reply #2 on: February 08, 2010, 12:09:17 PM »
Send member GORDON a pm. He has a 500/550 and may even live close to you.
Offline theofam
« Reply #3 on: February 08, 2010, 03:57:16 PM »
Triffecpa, thanks for the advice!  As a track bike, you probably don't spend much time under 3/4 throttle  ;D ;D, but, can you let me know what pilot jet and needle setting you're running, too?
Jerry, I'll drop Gordon a PM.  Thanks for the contact!
Offline Triffecpa
« Reply #4 on: February 08, 2010, 08:59:43 PM »
you are correct in that not a lot of time is spent below WOT.  Stock needle settings and pilot jet.
TR
aasp87
« Reply #5 on: September 16, 2010, 07:37:40 PM »
hey Theofam, how are you?
I live in México City (7000+ ft), and also have a CB550 with pods, what jet size works in your bike?
thanks
armando
