Author Topic: Carb stix v. Carbmate v. Twinmax v. CarbTune...  (Read 14903 times)
Online PeWe
Re: Carb stix v. Carbmate v. Twinmax v. CarbTune...
« Reply #25 on: March 22, 2019, 11:38:52 PM »
It is very easy to compare all 4 carbs with morgan carbtune and getting them equal.
https://www.carbtune.com/
Before syncing carbs, make sure your ignition is correctly set and equal. If 1:4 is set different than 2:3, engine will run as unsynced carbs.
Setting points equally with dwell meter will make the engine to run very even.
Properly bench synced carbs will work fine with a correct ignition.
Read this thread and become a believer you too!  ;D
http://forums.sohc4.net/index.php?topic=147444.0
Sloppy advancer springs another thing before tuning carbs. Important that F aligns with case mark at idle around 1200 rpm, if not, the bike will run very uneven under 3000 rpm. That's my experience after loooong excercise of tuning carbs to run even on lower throttle lift, finally sorted getting ignition right.
Offline pushin9s
« Reply #26 on: March 26, 2019, 07:55:53 PM »
+1 on the CarbTune.  Have used home made manometers and also a TwinMax.  The Twinmax only does 2 carbs at once and is very sensitive. I started my 1150 Beemer with it hooked up and didn't have the sensitivity all the way down.  Bang!!  Out of whack and now I have a nice $100 paper weight.  The CarbTune is very simple, seems rugged and was very accurate and comes with plenty of fittings for various bikes.
