Author Topic: F exhaust on a K?  (Read 711 times)
Offline Elniniomuchachos
F exhaust on a K?
« on: September 21, 2010, 10:21:49 PM »
Will a cb550 super sport exhaust fit on a K model 550?
Offline Skunk Stripe
Re: F exhaust on a K?
« Reply #1 on: September 22, 2010, 06:01:41 AM »
Wel I dont know for sure but on the 750, the spacing is the same. I would assume so on the 550 as well.
« Reply #2 on: September 22, 2010, 06:12:35 AM »
I believe the header will fit, but the muffler mounts are differant.
Offline bubruins
« Reply #3 on: September 22, 2010, 07:31:11 AM »
To have it bolt on the flanges tightly and correctly I had to bend the F pipe on my 550k. I tightened the pipe on w/o the gaskets and then used a blow torch, a 24" 1/2" drive extension, and a 230lbs friend to slowly coerce the pipe into a position that was clear of the frame and pedal. You will then have to get creative with the rear brake arm.
