The yamaha exhaust uses a 4 into 1 header where the pipes are spaced near even from eachother. As far as the angles go I will be using (from the engine) the first 6 or so inches of the stock pipes, then cutting both sets to match up, and welding them together which will be easy enough because the pipe diameters are the same.
