Author Topic: CB750A head removal...  (Read 2118 times)
Offline katmol
« on: September 22, 2010, 02:57:37 PM »
While checking the compression on the '76 CB750A I buggered the threads on #2 and can't get the plug back in. Am I right in thinking I can pull the head on a 750A without pulling the engine?
Thanks
'74 CB750K Tracy Project
'76 "Modified" GL1000
'77 CB750A Blue
'77 CB750A Red
'79 CM400A Hondamatic
'81 CM400A Hondamatic
"Gone but not forgoten."
'76 CB750A Muscat Green
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
'78 750K Black Dresser
KingCustomCycles.com
Re: CB750A head removal...
« Reply #1 on: September 22, 2010, 03:09:29 PM »
Yes you can, but wait! repair those threads with a helicoil insert.  The only trick is coating the tap with grease to catch the metal shavings when tapping for the insert. Been right where you are a couple of years ago.
Offline katmol
« Reply #2 on: September 22, 2010, 03:41:41 PM »
I'm hopig I don't have to go that far. It just started to bind on the first couple for threasd and I didn't force it any more. So I'm hoping I can just thread the plug in or a tap from the back side.
'77 CB750A Blue
'77 CB750A Red
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
