Author Topic: Gas leak puzzler??  (Read 2794 times)
Offline MikeJW
Re: Gas leak puzzler??
« Reply #25 on: September 29, 2010, 03:02:32 pm »
Thanks, TT. I'll look for it.
Mike
1972 CB750K2
Offline Johnie
« Reply #26 on: September 29, 2010, 05:21:48 pm »
Great, thanks, guys. I hope you're right. I've been sweating trying to figure how to hold it in the petcock. My fuel hoses have always been a tight fit...hard to get on, even harder to get off.
Mike
To keep from pulling my brass fittings off when removing the fuel hose, I put a little clean grease on the brass tube. Put it high enough so you do not get any in the fuel line. I never have trouble getting them off now.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #27 on: September 29, 2010, 05:34:45 pm »
Good idea, John.  ;)
Offline MikeJW
« Reply #28 on: September 30, 2010, 06:50:20 am »
Johnie,
if the grease isn't actually between the brass tube and the inside of the fuel hose, what good is it doing? I apologize if I misread your post, but that's what it sounded like. I wouldn't think a tiny little bit of grease inside the hose would hurt anything. Do you clamp your hoses to the tubes?  Regular screw-type hose clamps or something else?
Mike
1972 CB750K2
Offline j squared
  • www.iliketogofast.com
    • ILikeToGoFast
« Reply #29 on: September 30, 2010, 07:07:51 am »
I think he was saying the grease is between the tube and the fuel line, but not so far down that it is in the flow of fuel.
Offline Johnie
« Reply #30 on: September 30, 2010, 04:35:22 pm »
Exactly as j squared says. Between the tube and the line. To be honest, I have not used any clamps on my hoses either. I really should, but have not and never had a leak. If I use a clamp I would try the OEM ones.
Oshkosh, WI  USA
