Author Topic: Wiring Harness Question '73 750  (Read 848 times)
Objectionableone
« on: March 05, 2006, 01:30:36 PM »
Funny the things you don't notice until you start working on a bike.  My bike has no horn and no woking brake light switch on the front.  Here's the question:  does a normal/stock wiring harness have a pig tail for the horn and brake switch or are the connections in the head light?  Need to get those fixed before she will pass inspection.
Gratuitious pics:
Offline KCs76Cafe
  • Jackson Creek,NC..Deep in the stix of the TRIAD
Re: Wiring Harness Question '73 750
« Reply #1 on: March 05, 2006, 01:37:48 PM »
The brake switch has a pigtail off of the main harness and the horn connects in the bucket....I think.
I just need to figure out how to use a 73 right hand control on a 76.
Objectionableone
« Reply #2 on: March 05, 2006, 02:30:43 PM »
I was afraid of that - neither are obvious on my bike - I'll just need to work it out.
Thanks
« Reply #3 on: March 05, 2006, 02:37:42 PM »
750 K3 Horn gets 12 V from a black wire (switched from ignition switch)
The horn button grounds the other horn connection through a LG (Light Green) wire.  Beep!
The original bike had a hydraulic pressure switch on the lower fork tree.  You should find G/Y and Bk wires near that location.  When connected, the brake light should come on.  (when ignition switch is also on)
Objectionableone
« Reply #4 on: March 06, 2006, 04:03:40 PM »
K.C. and T. T. - many thanks.
