Author Topic: Kick Start Questions (71 CB500)  (Read 11254 times)
Offline Oddjob
Re: Kick Start Questions (71 CB500)
« Reply #25 on: April 15, 2011, 05:00:38 PM »
I'm having a nasty feeling about your engine, 2nd pic on post 17, shows the primary shaft and chain. However it also shows the oil gallery tunnel connecting the oil pump to the main journals, this appears to have a large crack in it, whether the crack is weeping I can't say but it don't look good to me. I'd say something hard has hit it from underneath, possibly a part from the gearbox. If it is cracked through to the inside of the tunnel then you'll be losing oil pressure, even if it's not weeping you may be wise to consider having it welded because if it goes whilst driving the engine will most likely sieze before you know it, the oil pressure switch sits on top of the oil pump and this will be pumping fine so it may not light at all to warn you.
The clip you found looks a lot like a piston gudgeon pin circlip, there are 2 on each piston stopping the pin from sliding out, I've seen them with those little tabs on the end to make removing them easier, circlips tend to have eyelets, especially the gearbox circlips. It's been a long time since I've taken one of these apart but having done over 100 of them over the years I can't remember a clip that style around the clutch area.
« Reply #26 on: April 15, 2011, 08:23:15 PM »
i dont think its a crack,might just be casting flaw,try blowing compressed air and see if it leaks.
Offline Oddjob
« Reply #27 on: April 16, 2011, 08:23:17 AM »
I've seen loads of casting flaws, I was a Honda mechanic for a long time and you get used to seeing them. They usually look like fine lines, they don't usually have a mark where it looks like something has hit them. I'm not saying it is a crack, I'm saying it could be, if nothing else it's worth investigating. If it was anywhere else except the oil gallery I probably wouldn't have said anything but the last place you want a crack is there.
Offline Čina
  • Noob
« Reply #28 on: April 16, 2011, 08:57:01 AM »
If this is the one you are talking about then the picture is deceiving. It is not a crack but more of a casting flaw. I'm not sure what it would be called in metal casting but when I was working in plastic injection moulds it was called flash. Where there was a bit of leak between two halves of the mold. You had me worried there for a bit but after a quick look it'll be ok. Thanks for the help either way.
Offline Oddjob
« Reply #29 on: April 17, 2011, 01:28:21 PM »
If you've checked it and your happy with it then I'm glad it's turned out to be nothing. Maybe the flas on the camera makes the little mark look a lot worse than it is, to me it looked like the centre of the line had an small piece missing, similar to a hit mark.
I thought I'd point it out, just in case.
« Reply #30 on: April 24, 2011, 09:04:43 PM »
No hockey? NHL finals are going on! Go Wings!
Offline Čina
  • Noob
« Reply #31 on: April 26, 2011, 11:07:29 AM »
I believe he was referring to the fact that I live in Calgary and the Flames didn't make the playoffs.;D Although, after tonight I may not have anything to cheer for if the Canadiens and Sabres both crash out. :-[
Also, I absolutely hate the Red Wings so that's not an incentive to watch. :D
