Thanks guys. Alan, this is a set i saved from Chris during the flood. They are labeled AW82-TRI which i think comes from a DOHC 750/900. He said they would work for a 750 so i was going to give them a whirl. I like the idea of being able to replace the wire. I found this in my searching
"Title: Re: Juicier coils
Post by: Robert on June 23, 2005, 06:07:20 pm
If you can use another coil depends most of the primary circuil. The dohc 750/900 coils (AW82TRI) have a resistance of 2.1 ohm (primary) and 12 Kohm (secondary)
AFAIK(
?) your coils have something like 4 Ohms at the primary circ. if so that would be quite a difference -> not good, too much current (good spark though, but only for a short time
What is this resistor pack you speak of? Is that the same thing as his magic ignition module??
