Author Topic: Idling problems on my 550f rebuild  (Read 743 times)
Offline catzor
« on: October 01, 2010, 11:49:14 AM »
The bike stopped running a while back and was parked by the PO. I got it running, then running even better with a simple points adjustment and thorough carb cleaning.
When I first started it after these adjustments, I was thrilled at the responsiveness of the engine and it's willingness to rev smoothly(in neutral).  I started off down the road and it still didn't want to rev much under load, but I down shifted, go the revs up, then it was like I had broken down a wall. The bike took off! As long as I kept the revs up it blasted down the road.
When I pulled in the clutch and stopped, I noticed it was running poorly at low revs again. Then it died. I had great difficulty getting it started again, and could only do so by having the throttle wide open.. By the time I got back to my place, it wouldn't start at all.This sounds to me like the pilots have clogged themselves again. What else could make it run poorly at low revs, then take off at high revs, then get dramatically and progresively worse in the course of a mile or so?  I had no airbox on, but I'm not sure how relevant that is.
1991 CB250 Nighthawk
1986 VT500C
1989 EX500
1973 CB175 Super Sport
KingCustomCycles.com
Re: Idling problems on my 550f rebuild
« Reply #1 on: October 01, 2010, 11:57:54 AM »
Plugged pilots are likely.  You lost 1 cylinder and it was sluggish, then you lost another one and it got real bad.  The "turbo effect" was the bike struggling past the low and midrange lean condition and using the unplugged main jets.  Just wait until it runs well from idle to redline, fun fun.  ;D
Online dave500
« Reply #2 on: October 01, 2010, 04:34:07 PM »
empty the fuel tank and get any crud out of it,also any fuel filters clean out or replace them,you dont want to be doing the same job over and again.
Offline catzor
« Reply #3 on: October 01, 2010, 06:08:19 PM »
That was what was puzzling. I pulled the carbs once, cleaned all the jets and reinstalled. I ran the bike for about five minutes(I was just seeing if it would try to start at all). I then took them back off to detail clean and the pilots were all at least partially clogged again even though the bike only ran for a couple minutes! I suppose I will find the same this time. There must be some sediment somewhere that's buggering things up.
1986 VT500C
1989 EX500
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #4 on: October 01, 2010, 06:15:37 PM »
empty the fuel tank and get any crud out of it,also any fuel filters clean out or replace them,you don't want to be doing the same job over and again.
+1
Have you removed the petcock to make sure the filter on the stand pipe is actually there?
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Raef
« Reply #5 on: October 01, 2010, 07:56:33 PM »
Ive been through the same thing cleaning the carbs and tank several times, even adding in line filters. Nothing fixed it till I spent the 25 bucks ordering and replacing the filter in the tank
« Reply #6 on: October 01, 2010, 11:09:11 PM »
clean clean clean your fuel system!
